32/36 electric choke question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 32/36 electric choke question
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread 08-28-2015, 08:33 PM   #1
RamadiRat
Cj 32/36 electric choke question
86 CJ7 284
weber 32/36
nutter bypass
I believe I understand the electric choke should be connected to a solid 12v switched when the ignition is switched on... which I have tested and know is good. Question is, does the choke just need this 12v feed or, should something else be in this circuit? Does it simply remain 12v hot the entire time the engine is running? If so, I wonder how the choke is opened or closed based on temp., etc. PO had a 12v feed (which was feeding 0) and.. a sensor was spliced in.. not sure why since had that 12v feed been hot, the sensor would have had no affect.
RamadiRat is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 04:19 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Sensor?? The choke is a timer choke that opens slowly as soon as it sees 12 volts and just stays open as long as it sees power. The stock setup uses an oil pressure switch so it only starts opening when the engine starts, not when the key gets turned.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
