305 in CJ5? - JeepForum.com
post #1 of 16 Old 06-03-2012, 08:33 AM Thread Starter
cj5ben
305 in CJ5?
So along with my YJ build, which is a lot more complete, I am working on 70 CJ5. My friend offered me his running 305 for pretty much nothing. How hard would this swap be and would the 305 be worthwhile for me? I have a 7ish inch custom spring over lift, rear is dana 44 with detroit locker and 5.38 gearing. Planning on 35 inch tires, i think.
cj5ben is offline
post #2 of 16 Old 06-03-2012, 08:54 AM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Swap isn't too bad but the 305 is a terrible engine.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #3 of 16 Old 06-03-2012, 08:54 AM
mopar408
1974 CJ5
clarification:
305 Chevy or 304 AMC?
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #4 of 16 Old 06-03-2012, 08:54 AM Thread Starter
cj5ben
305 chevy
cj5ben is offline
post #5 of 16 Old 06-03-2012, 08:55 AM Thread Starter
cj5ben
what are some downsides of the 305?
cj5ben is offline
post #6 of 16 Old 06-03-2012, 09:02 AM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
All of the small block Chevya from the 283 up to the 400 have redeeming qualities like ability to handle high revs or the make gobs of power in differing spots in the power band except the 305. It excels at nothing. Poor mileage, low power, and no one how how durable they are because they get sick of them and throw them out long before ever wearing one out!
post #7 of 16 Old 06-03-2012, 09:03 AM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
Originally Posted by mopar408 View Post
clarification:
Pretty sure they are both the black sheep of their families.
post #8 of 16 Old 06-03-2012, 09:10 AM Thread Starter
cj5ben
so it sounds like trying to find a 350 is a better option
cj5ben is offline
post #9 of 16 Old 06-03-2012, 09:19 AM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
Much better engine with a much better return on your investment as far as power adders and resale.
post #10 of 16 Old 06-03-2012, 09:21 AM
mopar408
1974 CJ5
plus on 305 heads, if you ever let the engine get hot even once, heads are FUBAR.
mopar408 is offline
post #11 of 16 Old 06-03-2012, 09:23 AM
mopar346
305s are good for striping to the bare block and using to mock up sb fitment, but other than that I cant think of a good use for them, they are too heavy to even make a good boat anchor.
EDIT: After reading 408's post I thought of another use, the heads WOULD make good boat anchors.
Long stroke, small bore just doesn't get it done. As mentioned useless engine, find a 350 pre or post TBI 350 if you must go sbc.
A few things to consider, isn't the 70 before they extended the front sheetmetal for the AMC engines? In a 5 you also need to be aware of the tranny lengths available.
Careful your character's showing
mopar346 is offline
post #12 of 16 Old 06-03-2012, 09:46 AM Thread Starter
cj5ben
yea i was thinking how to do the V8/trans swap as the frame is set up now for a 225 V6
cj5ben is offline
post #13 of 16 Old 06-03-2012, 10:00 AM Thread Starter
cj5ben
what are some transmission&transfer case options for a 305/350? I only have a T14a right now and have a offset rear axle
cj5ben is offline
post #14 of 16 Old 06-03-2012, 10:25 AM
dg6772
You may want to look at a Chevy 4.3 v-6. The vortec is 220 hp, roller cam & lifters, & can be carburated as well as fits in same space.
dg6772 is offline
post #15 of 16 Old 06-03-2012, 12:01 PM
mopar408
1974 CJ5
and change to a T-15. 15 and 14 exchange 100% and 15 is bulletproof.
mopar408 is offline
