304 will not turn off when key turned off and removed - JeepForum.com
post #1 of 6 Old 07-06-2013, 05:00 PM Thread Starter
Tweeter00801
1978 CJ7
I could use some help.
The 304 runs beautifully, but today for some reason, when I turned off the key, the engine did not quit while at the gas station. I accidentally turned it too far in the 'on' position, which gave power to the started, then returned the key to the 'off' position and only then did it turn off.
I returned the Jeep to my garage and turned the key to the 'off' position, and the engine would not turn off when I turned the key to the 'off' position. I could even removed the key. Nothing changed. I activated the starter by turning the key all the way 'on', and again, the engine would turn off. I don't want to do that again if possible.
Both instances, the engine ran exactly the same with the key in the 'on' position, and when the key is removed. In both instances, with the engine on, when I turned the key as if I was going to start it, the starter squelched, and the engine died when I turned the key to the 'off' position.
The Battery and Selenoid are new within the last 6 months. It runs great. The only thing I have done recently was change the engine oil, changed the transmission oil, and changed the headlights to KC-Hi-lites. I don't think I've done anything that would cause an electrical issue.
Any thoughts?
Tweeter00801 is offline
post #2 of 6 Old 07-06-2013, 05:30 PM
draperjojo
1946 CJ2A
You may want to double check the ignition switch down on the steering column if it's like my jeep. There is a little bit of adjustment..... do a search on it here.
draperjojo is offline
post #3 of 6 Old 07-06-2013, 05:56 PM
LumpyGrits
Bad ign. switch contacts.
LG
LumpyGrits is offline
post #4 of 6 Old 07-07-2013, 12:11 PM
jeep_boy02
1980 CJ7
x2 on double checking the switch and x2 on getting a new one... Have put three in mine and just feel like the system isn't a good design/ weak or cheaply made.
jeep_boy02 is offline
post #5 of 6 Old 07-07-2013, 02:04 PM
Elkaholic
NMElkaholic
Elkaholic's Avatar
Same thing happened to me.. it was the switch at the bottom of the steering column.
98 5.9, Platinum 4.5 RE SF all adjustable arms, RE Monotube Shocks, Carolina front drive shaft, Pro Comp Extream Alloys Stryker's, 285/75/16 BFG's KM2's,Stage 1 rock sliders,Confer roof rack,Warn XD9000i winch, 3" Kolak exhaust system, Addco front swaybar and lot's more goodies.. 79 CJ5 AMC 304 33x12.5 Pro Comp X-tream mud tires on 15x12 MT classics. 3" lift.
Elkaholic is offline
post #6 of 6 Old 07-07-2013, 03:03 PM
LumpyGrits
It's a GM column
Ain't nut'n wrong with it.....Look at all the dirt we get into
LG
ignition , key will not turn off , wont turn off
