304 vs 360 flex plate - JeepForum.com
post #1 of 8 Old 06-30-2017, 08:04 PM Thread Starter
chris989604
1980 CJ7
Hello,
I was getting ready to drop in the new 360 build and realized my machine shop used the 360 (3 convertor bolts) when balancing the assembly.
The flexplate for the 304 that i removed Has 4 convertor bolts. It was bolted to a 904. The 360 was out of a wagoneer, maybe a 400t or 727.
Anyway, I always thought the 304/360 had the same external weight and were interchangeable. My machine shop is not so sure. They can not look at it until Wednesday and i was hoping to drop it in this weekend.
Any knowledge will help
chris989604 is offline
post #2 of 8 Old 07-01-2017, 05:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I know the flywheels are balanced differently for the 304 and 360, so I assume the same applies to flex plates.
Matt
Matt1981CJ7 is offline
post #3 of 8 Old 07-01-2017, 04:14 PM Thread Starter
chris989604
1980 CJ7
I used rock auto and looked up parts mid 70s. 304 and 360 use the same flex plate when mated to the same 904 transmission. if it is a 400t or 727 it called for a different part number.
that is not saying rock auto is correct, I have ordered enough parts that are not right.
I guess i will wait and have the machine shop check the balance. No since is ruining the build on the last day.
Thanks,
Chris
post #4 of 8 Old 08-20-2017, 07:32 AM Thread Starter
chris989604
1980 CJ7
Matt
Matt,
You are 100% correct.
The flex plates are also different. Anyone reading this, I would not ever order a replacement flywheel or flex plate without having a machine shop balance them to match the one you are replacing.
Mine took a substantial amount of added weight to bring the 904 plate to match the 360.
Hope it helps someone.
Chris
post #5 of 8 Old 08-20-2017, 10:46 AM
simpleones
727 has a much heavier flex plate. 400t very thin and flexible. Just an fyi
simpleones is offline
post #6 of 8 Old 08-21-2017, 08:59 PM
CSP
727, 904 and 999 use the four bolt flexplate while T400 is the three bolt, and yes they are displacement specific regardless of what transmission is behind the engine.
CSP is offline
post #7 of 8 Old 08-24-2017, 10:02 PM Thread Starter
chris989604
1980 CJ7
That's the thing, they are all different but if you go to order one, they are all listed under the same part number 304- 401 .
post #8 of 8 Old 08-25-2017, 12:02 PM
CSP
Yep, I'm aware of that. It doesn't change the fact that the engines all require their own specific flexplate. A machine shop can determine the balance of an existing flexplate and match a new one to it.
CSP is offline
