304 V8 heater hose size? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 304 V8 heater hose size?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing our NEW JK tail light adapter wiring harness!!
Unread 04-10-2014, 07:02 AM   #1
indy24
Junior Member
indy24's Avatar
1976 CJ7
I was going to change out all of the hoses this weekend. What is the diameter of the 2 heater hoses? Thanks in advance.
indy24 is offline   Reply With Quote
Unread 04-10-2014, 12:32 PM   #2
ASteve
ASteve's Avatar
1972 CJ5
5/8 if I recall...but the one that connects to the water pump is 3/4. So, you'll need to put a straight fitting to reduce down to 5/8...
SC
http://www.astevecali.com
ASteve is offline   Reply With Quote
Unread 04-10-2014, 07:10 PM   #3
indy24
Junior Member
indy24's Avatar
1976 CJ7
ok, thank you.
Unread 04-10-2014, 11:56 PM   #4
82JeepCJ7
1982 CJ7
I ran a short section of 3/4 off the water pump, then used a 3/4 to 5/8 reducer.Works great and zero leaks.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
Unread 04-11-2014, 05:44 AM   #5
tjeep1
1978 CJ7
hoses
did same as above
tjeep1 is offline   Reply With Quote
Unread 04-12-2014, 12:10 PM   #6
indy24
Junior Member
indy24's Avatar
1976 CJ7
OK, good info thanks! Looks good, and I like your air line set up also 82 if that's what it is.
Unread 04-12-2014, 10:25 PM   #7
82JeepCJ7
1982 CJ7
Yup, I used the York AC compressor to make it into an OBA system.
The intake for the compressor is plumbed up to the air cleaner on the engine so I would not have to run a separate filter on the intake of the compressor.
The discharge line from the pump goes though a check valve, then to an air/water separator, a "T" off that T a line goes in under the dash to the pressure gauge. On the back of the gauge is another T where the pressure switch is located. I ran a line to the back where I have a 7 gallon portable tank behind the rear seat. I used a portable tank so I can disconnect it from the system and use it away from the vehicle if needed. I also have an outlet on the front by the grill.
