304 timing - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 304 timing
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 02-21-2015, 06:11 PM   #1
mallard3914
1978 CJ7
304 timing
Anyone out there have a pic of the timing marker; the piece of metal that is pointed to show that marker on the harmonic balancer. I see the mark on the balancer but I don't see the part that has the numbered markers.
mallard3914 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 06:52 PM   #2
streetpro
Observing GIC
streetpro's Avatar
1978 CJ7
If you are looking at the motor from the front, it would be the balancers 10 o'clock. (passenger side)
Is yours missing?
streetpro is online now   Reply With Quote Quick reply to this message
Unread 02-21-2015, 09:13 PM   #3
zillla
1975 CJ5
It is under the alternator.
It's very hard to see. You may need to de-grease and use a flashlight to find it.
Pull my finger
zillla is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 11:45 AM   #4
j33ping
1976 CJ5
What year is that V8 timing cover? My '76 V8 has TDC in the center.
j33ping is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 11:48 AM   #5
zillla
1975 CJ5
No idea.. I found the pic on the net as an example.. I just looked at mine and it is the same as the pic you referenced
Pull my finger
Unread 02-22-2015, 11:52 AM   #6
mallard3914
1978 CJ7
Same location as Zilla reported?
Unread 02-22-2015, 12:01 PM   #7
j33ping
1976 CJ5
Yes, same location. Look for the notches sticking out.
Unread 02-22-2015, 11:39 PM   #8
82JeepCJ7
1982 CJ7
The timing marks are cast into the timing cover
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
