304 tick!!! - JeepForum.com
post #1 of 6 Old 06-27-2013, 03:52 AM Thread Starter
Duckguy53590
304 tick!!!
Hey guys my 304 is ticking. Cold, warm dosent matter. Seems to be coming from the passenger side intake/carb area. I thought it may of been the choke tube gasket. I replaced that but no dice. Any ideas?
Duckguy53590 is offline
post #2 of 6 Old 06-27-2013, 06:26 AM
Jamesromeos
1979 CJ5
Lifters? I hve one that sticks and it makes a loud tick all of the time. but until I remove the intake in the rockers and rep.lace it, you will still be hearing it. it sucks trust me I know.
Jamesromeos is offline
post #3 of 6 Old 06-27-2013, 08:03 AM
texasdave
texasdave's Avatar
1980 CJ7
Get along screw driver and and hold the metal end near the pinging. Hold the plastic handle next to your ear and it will allow you to narrow it done to a specific area. Some times a leaking exhaust gasket will cause a similar sound. Be careful of rotating components while doing this.
texasdave is offline
post #4 of 6 Old 06-27-2013, 08:34 AM
KMD
1976 CJ7
Maybe pop the psgr. side valve cover. Check to see if any of the rocker arms are discolored. As said above could be a sticky lifter. you want to make sure all of the rockers are getting oil.If you find a dry rocker you will need to look further into it. probably time for some new lifters.
KMD is offline
post #5 of 6 Old 06-27-2013, 06:01 PM
OldTexas
Lifter sticking? See if you can get a can of Hydra Valve Clean by Siloo. You may be amazed.
Paved roads, another example of government waste!
OldTexas is offline
post #6 of 6 Old 06-27-2013, 09:10 PM
fuzz401
1978 CJ7
ex manifold leak
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
