304 runs like crap when hot - JeepForum.com
post #1 of 6 Old 08-14-2009, 07:17 AM Thread Starter
jhagerman
1976 CJ7
My CJ7 project (almost roadworthy now) runs pretty well until it heats up. It sputters at low RPMs and even dies sometimes. When hot, it idles high when in park or Neutral, but almost dies when idling in gear (auto trans). Have checked the timing (5 degrees BTDC in neutral with vacuum line to distributor detached and capped). Do I have an ignition problem or carburetor (Edelbrock, no idea what model) problem?
jhagerman is offline
post #2 of 6 Old 08-14-2009, 12:14 PM
swatson454
1983 CJ7
I would start first making sure that every possible source of a vacuum leak is eliminated. Base gasket, hoses, tees, manifold fittings and intake gasket... all of it. See what you can find out and we'll go from there
swatson454 is online now
post #3 of 6 Old 08-14-2009, 01:06 PM Thread Starter
jhagerman
1976 CJ7
Is there a way to eliminate all vacuum except advance on Carb? This thing did not run when I bought it, and I'm not sure it ever ran right with all currently installed/un-installed parts. At least one vacuum line has a screw in it to cap it off, the valve covers are aftermarket, I believe an air pump was once part of the factory equipment (part of power steering bracket is hacked off where I believe ot once resided), aftermarket carb, etc. What do I do here?
post #4 of 6 Old 08-14-2009, 01:20 PM
Andy5150
If it runs good cold, and gets bad as it warms, I would think its running rich. Maybe a stuck or misadjusted choke, idle mixture to rich.
Andy5150 is offline
post #5 of 6 Old 08-15-2009, 03:39 PM
djui5
2004 KJ Liberty
What year is it? Do you have that emissions set-up on the exhaust manifolds? What about that flap that opens on the passenger side exhaust where it meets the manifold? There should be some kinda springed device there. Forget what it's called. It's possible that isn't opening like it should.
Randy Wright,
Apache Junction, Arizona
2004 KJ lifted/etc
1974 CJ-6 being restored
djui5 is offline
post #6 of 6 Old 08-16-2009, 04:24 PM Thread Starter
jhagerman
1976 CJ7
All ports are capped on the manifolds. It's a 1976 CJ7. I know the passenger side exhaust manifold has been replaced. I think my best bet would be to remove/bypass all un-necessary vacuum/pollution control stuff, as I am finding out a lot has been hacked under the hood.
put motor back in and now runs like crap jefflacy Jeep CJ Forum 17 10-17-2009 01:07 AM
Runs Rough Then Runs Perfect coolhuh Jeep CJ Forum 9 08-17-2009 02:14 PM
Alternator belt broke now runs like crap. Dad03 Jeep CJ Forum 6 04-26-2009 09:40 PM
86 CJ runs like crap nosinjcted Jeep CJ Forum 7 12-03-2004 08:24 PM
heater runs and runs... duitinmud Jeep CJ Forum 1 11-16-2002 10:57 PM
