304 rebuild : Ring Position - JeepForum.com
post #1 of 13 Old 11-30-2009, 09:26 PM Thread Starter
cdjones
1979 CJ7
Starting to reassemble my 304, and have a question for all you motor builders about ring position. Haynes manual says to stagger compression ring gaps 270 degrees, which would be 90 degrees apart, but does not say where to position them. I always thought the oil ring seperator aligned with the wrist pin, oil ring retainers on a 1 inch overlap, and compression rings aligned on the skirt, 180 degrees apart.
Any opinions or advice?
cdjones is offline
post #2 of 13 Old 02-04-2013, 02:35 PM
ericksin
1982 CJ7
Bummer........ i have the same question
**** it, GAS IT!
ericksin is offline
post #3 of 13 Old 02-04-2013, 03:12 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Here's how I did mine.
From the book "BJ Builds an AMC".
Matt
Matt1981CJ7 is offline
post #4 of 13 Old 02-04-2013, 05:20 PM
ericksin
1982 CJ7
Matt
Coool thanks
**** it, GAS IT!
ericksin is offline
post #5 of 13 Old 02-04-2013, 05:28 PM
Jack61
1981 CJ7
Your new rings should have instructions with them. Go with them because ring manufacturing has evolved over the years.
It used to be, God bless America, it has become God help America
Jack61 is offline
post #6 of 13 Old 02-04-2013, 05:54 PM
ericksin
1982 CJ7
They came with nothing
**** it, GAS IT!
ericksin is offline
post #7 of 13 Old 02-04-2013, 06:01 PM
Brewski
You can start them off staggered but it really is not a critical part of your engine build. They will travel while the engine is running.
Brewski is offline
post #8 of 13 Old 02-04-2013, 06:05 PM
Jack61
1981 CJ7
That's odd. Most all ring manufactures have instructions with their ring sets specifying ring orientation. You might do a web search for your ring manufacture installation instructions.
Jack61 is offline
post #9 of 13 Old 02-04-2013, 06:23 PM
ericksin
1982 CJ7
yep that's what i thought, i will look in to that
**** it, GAS IT!
ericksin is offline
post #10 of 13 Old 02-04-2013, 06:28 PM
ericksin
1982 CJ7
Interesting i never thought about that, i though you install them a certain way and that's where they stay...... but i guess i would have seen wear marks
**** it, GAS IT!
ericksin is offline
post #11 of 13 Old 02-04-2013, 06:56 PM
ericksin
1982 CJ7
Matt
Did you use a curtain install lube? or just a heavy oil...
**** it, GAS IT!
ericksin is offline
post #12 of 13 Old 02-04-2013, 08:39 PM
Jack61
1981 CJ7
It is very critical that you install and stagger the rings to manufactures specs or you may end up with a oil burner or low compression, the rings don't rotate on the piston. Use the same engine oil that you plan to put in the crankcase to install the pistons.
Jack61 is offline
post #13 of 13 Old 02-04-2013, 08:53 PM
Brewski
http://en.wikipedia.org/wiki/Piston_ring
Mark em, put them in and run a few 1000 mile. They will not even be close to where you left them. That said I do suggest as stated above that you start them in the correct position. IMO it is thr crosshatching that makes them travel. Pretty cool, huh.
Brewski is offline
How to keep power to FI ECU with key in Start position Dad03 Jeep CJ Forum 2 09-21-2009 02:04 PM
79 CJ5 304 won't run when key is in on position wv79cj5 Jeep CJ Forum 10 05-11-2009 08:53 PM
What causes key to return to the run position? 243 Jeep CJ Forum 1 07-23-2008 08:25 PM
TF999 tranny ring missing in rebuild kit valkster Jeep CJ Forum 0 02-28-2008 08:48 PM
Transmition Position??? Kurt_Kab_CJ7 Jeep CJ Forum 5 12-14-2005 06:57 AM
