304 Normal operating temperature? - JeepForum.com
post #1 of 15 Old 12-23-2009, 07:53 PM Thread Starter
Mudviper
What is the normal operating temperature of a 304? I know it probably depends on what thermostat is installed, but when I let the CJ7 idle it runs normally around 160 to 180. When I start driving down the road it drops to around 140 and a little below. I have never had an engine run that cold before and this is my first CJ, all my others have been XJ's and YJ's and they stay pretty consistent at 190 to 200 even when driving around. It's had been around 25 to 40 degrees outside so that could be a reason why it is running so cold.
Thanks
Mudviper is offline
post #2 of 15 Old 12-24-2009, 01:32 AM
KMD
1976 CJ7
Thanks
That is where mine runs but I have a constant drive flex fan. The fan makes it run really cool which is good because it dosent take long for an AMC V8 to overheat. So you are fine. I plan on putting in an electric fan motor and shroud in the future.
KMD is offline
post #3 of 15 Old 12-24-2009, 05:58 AM Thread Starter
Mudviper
I am running duel electric fans on it right now and they do not come on until the engine temp comes up to 180, so if I am running at 140 while driving around, the fans never come on..lol. It actually takes quite awhile for the engine to come up to 180 when idling
Mudviper is offline
post #4 of 15 Old 12-24-2009, 06:38 AM
jfwireless
1976 CJ7
The thermostat determines the operating temp if all is well with the cooling system, so it sounds like you have a very low thermostat for your 304. I have a 180 degree thermostat in my 304 and it runs under 200 degrees all the time. It sounds to me like your thermostat is a little low, 140 is to cool for the 304 in my opinion. I have a junkyard TBI install on my 304 and it would not even go into closed loop at 140 degrees. I believe the default temperature for GM TBI closed operation is 160 degrees. As I recall the stock thermostat for the 1976 304 was 195 degrees with the engine always above 200 degrees.
No matter what type of cooling fan you have it is the thermostat that determines the operating temperature for the engine, assuming you have enough cooling capacity for the designed operating temperature.
Jim
jfwireless is offline
post #5 of 15 Old 12-24-2009, 06:41 AM
KMD
1976 CJ7
Do you have a thermostat installed?
KMD is offline
post #6 of 15 Old 12-24-2009, 08:20 AM
_Kyle_
_Kyle_'s Avatar
Well this thread makes me fell better.
I just got my 304 running and with the electric fan on (sounds like a jet taking off), the thing barely reaches 130 when driving. With the fan off, it was about 160 when driving - but i'm DEATHLY afraid that my temp gauge is wrong and I'm afraid to leave the fan off in case I cook my motor.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #7 of 15 Old 12-24-2009, 01:51 PM Thread Starter
Mudviper
Jim
How does that TBI conversion work for you? I have only had my CJ7 for about and month and took it out for the first time to do some hill climbing and it was getting a bit frustrating stalling all the time with the carb. Would like to do a fuel injection conversion on it.
Mudviper is offline
post #8 of 15 Old 12-24-2009, 03:14 PM
jfwireless
1976 CJ7
The junkyard TBI 304 has never ran better. Getting around 18mpg, used to just make 10. It took some time but worked out just fine.
Get the proper thermometer and read the cooland temperature to compare to your temp gauge
Jim
post #9 of 15 Old 12-24-2009, 04:49 PM
_Kyle_
_Kyle_'s Avatar
Jim
Definitely, just a matter of getting to it... Been really busy and will be to the weekend. Then i've got Sat/Sun to work on it all day. But i'll definitely check it.
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #10 of 15 Old 01-18-2010, 10:32 AM
UncleBrad
1978 CJ7
So the proper operating temp for the 304 is what?
(wife here, hubby asked me to sign on and find the answer to this question)
Just got this Jeep and it seems like there's been many mods made to it.
TIA
Terri
UncleBrad is offline
post #11 of 15 Old 01-18-2010, 10:37 AM
CSP
As said, it depends on the temp of the thermostat used.
With a 180 thermostat the temp should not drop below 180
With a 195 the temp should not drop below 195.
If the thermostat is doing it's job it will open/close at the temp stamped on it. Temps can go higher than the stamped temp if the cooling system isn't doing its job, but they shouldn't go lower for any length of time.
CSP is offline
post #12 of 15 Old 01-18-2010, 10:42 AM
UncleBrad
1978 CJ7
Thanx CSP, I'll go out to 'Man Camp' and let him know.
Terri
post #13 of 15 Old 01-18-2010, 10:48 AM
_Kyle_
_Kyle_'s Avatar
I just put a new thermostat in my CJ with the 304. Little did I know the one in it had a piece of wire jammed through it! NO WONDER it wouldn't get to temp or anything!! Not it runs around 195 all the time.
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #14 of 15 Old 01-18-2010, 11:40 AM
jfwireless
1976 CJ7
I have a 180 degree thermostat and my 304 never goes over 200 degrees. As i remember the stock thermostat was around 195, and the engine ran hotter than it does now. As I recall up to 220 degrees. As I live in South Florida I wanted to get a head start on the heat build up.
Jim
post #15 of 15 Old 08-05-2014, 04:07 PM
bth8706
1977 CJ5
I have a 77cj5 with a 304 two 12 inch electric fans and the 1:1 ratio fan on the motor I live in Georgia the temperature today is 93 and high humidity I also have autometer gauges that I just put in and my jeep is running approx 210 going down the road is this too high? I also just had the radiator rodded out I am not running a fan shroud.
bth8706 is offline
Normal operating Temperature todbld Jeep CJ Forum 5 08-03-2009 08:18 AM
driveshaft operating range blutowski Jeep CJ Forum 6 05-03-2009 07:49 AM
304 operating temp? TexasGuns Jeep CJ Forum 5 05-30-2008 12:44 AM
Normal temperature for AMC304 ? JonCJ5 Jeep CJ Forum 6 09-03-2006 08:54 PM
Operating Temps JeepConvertNoob Jeep CJ Forum 3 07-11-2006 06:26 PM
