304 flex plate on a 258? - JeepForum.com
post #1 of 6 Old 12-08-2011, 03:24 PM Thread Starter
Oldcraneguy
1982 CJ7
I know the 360 and 401 flywheels/flexplates are weighted but Im thinking I read somewhere that the 304 wasnt and could be used on 6 cyls, anyone know if this is true? or was I just dreaming....thanks....OCG
Oldcraneguy is offline
post #2 of 6 Old 12-08-2011, 04:08 PM
CSP
Just dreaming. All of the AMC V8's are externally balanced and the 6cyls are internally balanced. The 6cyl flywheel has to be neutral balanced and the 304 won't be that way.
CSP is offline
post #3 of 6 Old 12-08-2011, 04:40 PM
mopar408
1974 CJ5
^^^^^^^^what he sez.
But, since you are going from "weighted" to "unweighted', they may, may use a neutral-balanced wheel like a six needs and then balance it from there. And that would ONLY be on an automatic ('flex plate" is the term).
If it is an auto and appears symmetrical with the exception of some form of weight attached/welded/whatever
you could cut it off and use it on a six.
304 flywheel has a small (1" x 2"? ) weight CAST into the backside. I6 has 3 ribs cast 120 degrees apart.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #4 of 6 Old 12-08-2011, 04:58 PM Thread Starter
Oldcraneguy
1982 CJ7
Oh well, I found a 304/727/300 for a buddy of mine who is building a 258 and wants the auto, guess he'll just have to buy a flexplate unless this ones got a weight I can cut off....thanks for the info....OCG
post #5 of 6 Old 12-09-2011, 08:03 AM
CSP
Any '80-86 CJ with an auto and 258 would be right application for the flexplate that the 727 needs. Those years came with the TF904 or TF999, but they use the same flexplate as the 727.
CSP is offline
post #6 of 6 Old 12-09-2011, 08:06 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
That's just one variant. There's a six-rib casting, also.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
I6 with TF999 Flex Plate VACJ7 Jeep CJ Forum 6 03-16-2010 06:47 PM
TF999 and Flex Plate VACJ7 Jeep CJ Forum 4 08-11-2009 05:38 PM
which flex plate do I need ctm Jeep CJ Forum 3 06-27-2009 11:33 AM
Flex plate broke. Need Help! CJ-22 Jeep CJ Forum 8 01-23-2007 11:08 AM
AMC 360 Flex Plate CJ-22 Jeep CJ Forum 20 01-07-2007 12:34 PM
