304 in a CJ5 - JeepForum.com
post #1 of 14 Old 12-30-2013, 11:11 AM Thread Starter
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
304 in a CJ5
I just found a deal on a 304 out of a 79 CJ (I think it was a 5).
I'm wanting to put this into my 75 CJ5 that started life with a 258 and currently has a 232 in it. The goal is to get this bolted between the frame rails in one day as I'll have to rent a cherry picker.
I've read some things that the passenger motor mount will need to be changed. The VIN says it has a T14, but the PO says it's a T15. Being as the engine was swapped and the tub is a badly chopped CJ7 tub, neither would surprise me. As soon as I get some time, I'll crawl up under and verify the casting numbers and measure the tranny.
Is this doable? I've never done an engine swap before, so perhaps I am over simplifying it. But I'm hoping I can get it lined up on the bellhousing and set it on the motor mounts and bolt everything up. If I can get that done in one day I'll be happy.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #2 of 14 Old 12-30-2013, 12:33 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
no problem.. find another '75 era cj and measure from a known point to the center of the motor mounts.. measure yours and figure which side has to be cut off and replaced.. cut it loose, get your welder out, weld on the new one in the right spot and drop it in.. my '75 had a 304 in it.. my '78 came with a 304 and I changed it to a 401 HiPo.. basically same, larger intake, MUCH more horsepower.. but the 304 is a good one..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #3 of 14 Old 12-30-2013, 12:37 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think a day is doable, if you have the old engine completely ready to lift when you bring the cherry-picker home.
A handy helper would almost guarantee it.
Good luck,
Matt
Matt1981CJ7 is online now
post #4 of 14 Old 12-30-2013, 01:17 PM
CSP
There's no need to cut and weld anything. The motor mounts bolt onto the frame rails.
The '75 and older mounts are a little bit different than '76 and up at the frame side. The later ones will work, but one of the holes will be off.
There's lots of info on this swap here: http://www.jeepforum.com/forum/f8/of...thread-377983/
CSP is offline
post #5 of 14 Old 12-30-2013, 02:57 PM
Jamesromeos
1979 CJ5
With a lift and air tools I had my 4.2 out and the 304 in with new mounts, all accessories, brackets, and much of the wiring done in 5 hours. The next day spent 3.5 hours working out all of the things I missed, tune, time ETC. All in all my first swap alone....easy!
Jamesromeos is offline
post #6 of 14 Old 12-30-2013, 03:08 PM
JeepHammer
Running On Empty...
1973 CJ5
If the 304 is running right, you won't be able to slap the smile off your face for at least a week. Nothing like a go cart with a V-8!
Fingers rubbing the back wheel while you are sitting in the drivers seat and having a V-8 at the other end of the 'Skinny Pedal'!
I punched in a 360 (Grow on trees) and started breaking parts. Turns out things like drive shafts and front axles, rear axle flanges don't like even stock 360 very much, so 304 is about perfect if you don't want to start the break it/fix it cycle...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #7 of 14 Old 12-30-2013, 03:22 PM
bradleybrb
1975 CJ5
My 304 swap went it easy too. My 304 was out of a 78. I swapped my 258 out for it. One of the motor mounts was different. My biggest problem was lining the transmission back up and getting it bolted to the motor. I could have used some help there. I put my t14 that was behind my 258 behind the 304. It works fine, but the 304 might eat it if I really got ruff with it. I think you can do it in a day easy if you have your ducks in a row.
bradleybrb is offline
post #8 of 14 Old 12-30-2013, 04:56 PM Thread Starter
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Thanks for the words of encouragement. I just pulled the trigger on these. I think I'll send them out and have them powdercoated ahead of time. Or just sand blasted and paint/prime them myself.
http://www.ebay.com/itm/271358567658
dagr8tim is offline
post #9 of 14 Old 12-30-2013, 05:20 PM
CSP
Hmm, I hope those were from a CJ. If they are from a fullsize Jeep they won't work as the frame rails are further apart on the FSJ.
CSP is offline
post #10 of 14 Old 12-30-2013, 10:52 PM
Rollbar
1984 CJ8
We took Jr's 304 out and replaced it w/a 360 etc. Find a 360 IMHO
http://www.jeepforum.com/forum/f8/jr...oject-1519633/
<----Click
<---- Click
Rollbar is offline
post #11 of 14 Old 01-02-2014, 10:31 AM Thread Starter
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Guy seems to specialize in CJ parts, so I'll hold out hope. I only need the brackets and the passenger frame mount. Even if they are from an FSJ, repop brackets would be more than what I paid for all of that.
Thanks for the info. That may be Stage II. ;-)
dagr8tim is offline
post #12 of 14 Old 01-02-2014, 08:41 PM
BeastOfBurden
1973 CJ5
You will be immensely happy with the 304 brother.
BeastOfBurden is offline
post #13 of 14 Old 01-02-2014, 10:51 PM
KultureCJ5
1976 CJ5
Love my 304!! Where I ever I go folks wanna know what's under the hood.
KultureCJ5 is offline
post #14 of 14 Old 01-02-2014, 11:39 PM
only in a jeep cj
Yes, those are what you need. The 75 and back engine mount frame bracket holes are different than the 76 and later. So if those are from a 73 CJ5, your good. The way to tell the block brackets difference between the CJ and FSJ V8s is the FJC is taller and flat when placed on a table mount side up. The CJ is shorter and slopped at an angle.
I was lucky and got the whole donor CJ. I swapped in the engine,brackets,exhaust, T-15 (that is used with the 304 vs the T14 used with the 6cyls), the engine wiring harness, and the fuel lines. I also swapped in the power steering box and lines.
The T-14 used the forward set of crossmember holes at the frame rails while the T-15 uses the rear set. Its a slightly bigger and loner unit. Insides are beefier too.
Testing out the 304 after the install. The braking sound at the end is me stopping before I go out into the street.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
