304 Carb Suggestions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 304 Carb Suggestions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 02-03-2014, 02:59 PM   #1
whitworth
1980 CJ7
I bought a 80 CJ-7 about a year ago. It has the 304 and the 4 speed. It looks like someone put a holley carb on it but only information I can find on it shows its from an old Ford truck. What carb would you recommend I buy for it? Thanks
whitworth is offline   Reply With Quote
Unread 02-03-2014, 05:14 PM   #2
arkiemurph
If it's still a 2 barrel intake I'd go back to original Motorcraft. They're great carbs.
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline   Reply With Quote
Unread 02-03-2014, 08:57 PM   #3
jeep_boy02
1980 CJ7
X2 ^
jeep_boy02 is offline   Reply With Quote
Unread 02-04-2014, 06:44 AM   #4
whitworth
1980 CJ7
Thats what I had thought. Thanks guys. I have seen a few on eBay, is that a good place to start?
Unread 02-04-2014, 06:58 AM   #5
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Not in my opinion.
I'd get it from it National Carbs. Every carb they sell is dyno-tested and comes with a good warranty. And their customer service is top notch.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 02-04-2014, 07:27 AM   #6
jeep_boy02
1980 CJ7
I may be wrong but I think the 2100 was stock and the 2150 had the bigger venturi... ??? Not a carb guru tho
Unread 02-04-2014, 07:28 AM   #7
CJ7nvrstk
Originally Posted by Matt1981CJ7 View Post
Not in my opinion.
Matt
They have some good prices,
2011 JKU OME HD lift, Viper TB, 35x12.50-15 PC Xtreme M/T
1985 CJ-7, built 360, T18/D300, 4.88s rear spool
CJ7nvrstk is offline   Reply With Quote
Unread 02-04-2014, 07:31 AM   #8
swatson454
swatson454's Avatar
1983 CJ7
Is there anything wrong with the current carb? Just wondering if a rebuild might save you some headache if you have to swap a bunch of linkage and what-not to get a MC on there.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote
Unread 02-04-2014, 07:35 AM   #9
Matt1981CJ7
1981 CJ7
Yep.
They will also custom configure your carb to your engine's specifications, including jetting for altitude, no extra charge.
Matt
Unread 02-04-2014, 07:44 AM   #10
CJ7nvrstk
Yep.
Matt
That is some good customer service. It sure beats going to Autozone!
Unread 02-04-2014, 07:54 AM   #11
Matt1981CJ7
1981 CJ7
Agreed. Here's their description of their carbs:
"In order to provide you the highest quality remanufactured carburetors in the industry, each carburetor is individually built by our certified technicians using a master rebuilding kit. All other components are cleaned, tested or rebuilt to meet O.E.M Specifications. The base plates are rebushed to remove excess wear from around the throttle shaft to stop certain vacuum leaks. All bolts and linkage parts are zinc plated. As well as casings are tumbled to chrome like finish. Or by special request, Dichromate finish can be applied.
We recalibrated the carburetors for today's gas and remove the inherent problems like hesitations, flat-spots and hard hot starting. Every carburetor goes through a 3 step testing process, first a float bench and pump test, second a dyno flow bench test, and then a live engine test. All the adjustments are set for a bolt on and go carburetor."
You won't get that level of manufacturing from the "ebay guy".
Matt
Unread 02-04-2014, 07:57 AM   #12
Speedy94c
Junior Member
Speedy94c's Avatar
1977 CJ5
I love the holleys. We have ran them on our race cars for years and are virtually trouble free and easy to work on. Most rebuild kits are in the $20 range and easy to put in and adjust. Id go with that option if it were me, saves money and time and headache with putting a different style on it.
Speedy94c is offline   Reply With Quote
Unread 02-04-2014, 08:05 AM   #13
jeep_boy02
1980 CJ7
Thing with tge MC2100 series is that they are one the best carbs for off road use... almost no problems with off camber and steep inclines. Sure a holley is easy and cheap for a car on the street or track but even the truck avengers aren't as reliable on the good hills.
Unread 02-04-2014, 10:14 AM   #14
whitworth
1980 CJ7
The carb on it now floods very easily on any incline. I had it rebuilt once by a friend and it didnt change much. I dont mind spending a couple hundred bucks on it if it makes my jeep that much more reliable. As far as modifications to make it work, what would I have to do?
Thanks again
Also, what kind of choke would I want? It says the options are climatic, electric and compenstator value?
Unread 02-04-2014, 10:58 AM   #15
Matt1981CJ7
1981 CJ7
I prefer electric.
