304 block head surface - JeepForum.com
post #1 of 5 Old 06-24-2013, 03:54 PM Thread Starter
79cj7amc304auto
Hi there I'm reinstalling my head and there are two metal sleeves on each side of the block on drivers side and only one in front on passenger side. These sleeve are raised and help to hold the gasket in place and since I'm missing the one in the rear on the passenger side I'm worried about the gasket slipping when I drop the head down. Any suggestions? I'm not using gasket sealer so I guess my main question is is that sleeve absolutely necessary or could I do this without that piece in place? If I were to replace it where would I fin an exact replacement? Is it something I'm gonna hafta fabricate? I so where do I get the material? A piece of 1/2 inch copper fits perfectly over the sleeves so that is the rough outside diameter.
79cj7amc304auto is offline
post #2 of 5 Old 06-24-2013, 04:46 PM
roboto65
1976 CJ5
Was it always missing or maybe did it stick in the head when you pulled it off like mine not sure where to find a replacement but sure someone on here will chime in and have one on a old block.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #3 of 5 Old 06-24-2013, 07:52 PM
fuzz401
1978 CJ7
like said check your heads to see if they are in them if not check napa they should be able to get they
they are needed to keep the head in the right place
found this
The head dowels are still dealer parts (Mopar) since they're the same as the last 360 used in 91.
J400 5149 is the part number.
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 5 Old 06-24-2013, 08:25 PM
texasdave
texasdave's Avatar
1980 CJ7
Machine shops usually keep a pile of them around.
texasdave is offline
post #5 of 5 Old 06-24-2013, 10:57 PM Thread Starter
79cj7amc304auto
Thanks so much!!! The machine shop guy in town thinks he can get one for me tomorrow. Sweet... I can keep building!!!! I owe ya all one!!! I will return the favor by helping out someone else here when I can.
