304 auto/manual flywheel/flexplate - JeepForum.com
post #1 of 7 Old 09-08-2010, 09:08 AM Thread Starter
RjTack
Hi All,
Is the flex plate/ flywheel the same for the auto tranny as the manual? I'm swapping in a 304 that was hooked to a manual 3-speed to my '85 CJ7 that had a 258 and has an auto trans. Do I need to locate a flywheel from a 304/Auto trans, or will the torque converter bolt up to a 304 manual trans flywheel?
RjTack is offline
post #2 of 7 Old 09-08-2010, 09:19 AM
BioTex
1979 CJ7
Automatics have flex plates. Standards have flywheels. You need a flexplate balanced for a 304 behind the motor, to go with an automatic. Hope this helps.
Edit:
While you have it apart, don't forget to change the pilot bushing/bearing.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 7 Old 09-08-2010, 09:55 AM Thread Starter
RjTack
Flex plate re-balancing
Anyone know if I can get my 258 flex plate re-balanced to use with a 304? If so were would I get that done?
RjTack is offline
post #4 of 7 Old 09-08-2010, 10:01 AM
BioTex
1979 CJ7
Post in the wanted section of the classifieds on this forum. That's where I got one. Re-balancing is done at a machine shop. Cheaper to purchase a used one probably. I'm not certain if it is possible to do without the crankshaft out.
Currently:
BioTex is offline
post #5 of 7 Old 09-08-2010, 12:37 PM
h2ojeep
1978 CJ7
Each AMC engine has a unique harmonic balancer and flexplate (fly wheel if standard transmission) and cannot be mixed between different types of engines. A 258 cannot be put on a 304, 304 cannot be put on a 360 etc. However a they can be changed between the same engine, 304 from one engine will go to another 304.
So as Biotex said, you might do better finding a used flexplate from another 304 verse the expense and logistics of balancing .
New is not all that bad a price
Flywheel, Automatic Transmission 8 Cyl AMC 304*5351820 by the Jeep Specialists | Morris 4x4 Center
Hope this helps
h2ojeep is offline
post #6 of 7 Old 09-09-2010, 08:41 AM
Supertrucker
1979 CJ5
Don't know exactly where you are, but I have a 304 flexplate I just removed from the motor I am dropping in my CJ5. It's yours if you want it, just pick it up or pay shipping and I will get it on it's way to you. Let me know, I will be back on here tomorrow night or sometime Friday.
Supertrucker is offline
post #7 of 7 Old 09-11-2010, 12:03 PM
Supertrucker
1979 CJ5
PM sent. Sorry for taking so long to get back to you. I broke down on the way home and spent last night at a lovely diesel shop in Lexington, Ky. I'll let you know what shipping costs Monday morning.
304 , auto trans , flexplate , flywheel , torque converter
Auto to Manual?? SPless Jeep CJ Forum 12 07-18-2010 09:23 PM
manual to auto Redmanchew Jeep CJ Forum 4 12-15-2006 12:44 PM
Manual Vs. Auto jeepsarecool Jeep CJ Forum 13 03-28-2006 07:10 PM
from auto to manual rick95 Jeep CJ Forum 6 12-18-2005 03:55 PM
999 auto to manual??? ollietonk Jeep CJ Forum 3 03-01-2004 09:57 AM
