304 Air Cleaner Housing for Edelbrock 4 Barrel - JeepForum.com
post #1 of 9 Old 11-10-2011, 07:15 AM Thread Starter
Hurricane4
This info and the photos are in the thread titled " Carburetor Spacer for
Edelbrock Performer AMC ". Thought I would post this as a new thread since
this is more of a new topic.
I ditched the open air cleaner and found this air cleaner from a V8 Dodge full
size van (94-97 I think) that fit the Edelbrock carb fine and cleared
everything.
This really helped almost eliminate the fuel odor in the garage when I pulled
the Jeep in and did not affect performance as far as I could tell. Now I need
to fab a cold air intake tube.
Air Cleaner housing part number: 53008275
Air Cleaner Duct (angled plastic adapter) part number: 53006259
Air Cleaner Element: Purolator A40004 (NAPA was closed Sunday)
The unbelievable we can do immediately . . . the impossible just takes a little longer.
Hurricane4 is offline
post #2 of 9 Old 11-10-2011, 08:18 AM
frankenstienCJ
1978 CJ7
What do you mean gas odor When you pulled in? I do not see how the two are related.
frankenstienCJ is offline
post #3 of 9 Old 11-10-2011, 08:43 AM
85LaredoCJ7
I would like to know where you found the parts. I searched the part numbers for the the air cleaner and adaptor, and couldn't find anything.
85LaredoCJ7 is offline
post #4 of 9 Old 11-10-2011, 09:50 AM Thread Starter
Hurricane4
The gas odor was from the engine compartment open air cleaner and the
previous carb (Edelbrock Performer 600cfm mechanical secondaries) probably
was not helping.
FYI - I am using the proper fuel filter with the vapor recovery and all the
charcoal canister connections are hooked up except for the carb fuel bowl
vent because the Edelbrock carb does not have a bowl vent connection.
The part numbers were stamped into the air cleaner housing base and into the
plastic angled adapter. I ran across these items on eBay.
Check 94-97 Dodge full size V8 vans.
post #5 of 9 Old 11-10-2011, 09:51 AM Thread Starter
Hurricane4
I will double check the part numbers.
post #6 of 9 Old 11-10-2011, 11:13 AM Thread Starter
Hurricane4
I have two of these air cleaner housings and the one in the garage has a
sticker on the top of the "snout" with the numbers 53008275 and 1762B.
The number stamped in the bottom of the air cleaner housing "snout" is
53008277.
Check part numbers here:
http://atascosa.com/parts/chry279.html
53008277 BODY AIR CLEANER
53008280 LABEL AIR CLEANER I.D. NS2
53006252 DUCT -GRILLE TO AIR CLEANER NS1
53006256 DUCT AMBIENT AIR NS1
53006258 DUCT RADIATOR GRILLE TO FLEX D
53006259 DUCT AIR CLEANER
53006262 DUCT AMBIENT AIR (3.9-5.2L) NS1
53006268 DUCT AMBIENT AIR (2.5L-SPI) NS1
53006269 BAFFLE FRESH AIR ENG INTAKE NS1
53006272 HOSE AIR CLEANER TO T/BODY
53006273 RETAINER AIR CLEANER DUCT
53006275 HOSE AIR CLEANER TO T/BODY
post #7 of 9 Old 11-10-2011, 11:21 AM
colojeepguy
1970 CJ5
You can also use one off a V8 Wagoneer
colojeepguy is offline
post #8 of 9 Old 11-10-2011, 11:23 AM
CSP
Just about any 70s-80s V8 air cleaner housing would work. They all used the same 5-1/4" carb throat opening.
CSP is offline
post #9 of 9 Old 11-10-2011, 11:30 AM Thread Starter
Hurricane4
Thanks for the info colojeepguy & CSP. I liked how this air cleaner housing is
somewhat a low profile design and it fit great. Another plus is no emissions
connections / hose hook-ups other than the one for the oil cap.
Edelbrock carb - Stud for Air cleaner? greenersport Jeep CJ Forum 8 08-11-2013 07:15 AM
Air Cleaner Housing Edmund Jeep CJ Forum 2 07-01-2011 08:01 AM
Air cleaner for 4 barrel carb LSUtiger Jeep CJ Forum 6 05-03-2011 02:14 PM
AMC 4 Barrel other than Edelbrock? JeepnBlake Jeep CJ Forum 6 05-14-2008 08:57 PM
Air Cleaner Housing 81CJUSMC Jeep CJ Forum 7 02-17-2008 08:03 AM
