Quantcast 304/360 interchange - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 304/360 interchange
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 09-05-2002, 01:11 PM   #1
rmclague
304/360 interchange
Are the Amc 304 and the Amc 360 completely interchangeable?
will parts such as intake and exhaust from the 304 work on the 360?
Are there any advantages to using the 360 over the 304?
Any help you have is appreciated.
Rob
rmclague is offline   Reply With Quote
Old 09-05-2002, 02:13 PM   #2
CSP
Externally they are exactly the same, so yes intakes and exhaust will swap from one to the other. Reasons for a 360 over a 304? There's no substitute for cubic inches! What else would you wonder about?
CSP is offline   Reply With Quote
Old 09-05-2002, 03:03 PM   #3
OldJeepguy
1979 CJ7
I just finished this swap about 4 months ago - the 360 is a direct bolt-in and has huge HP & torque gains over the 304.
Steve
jeep79cj@yahoo.com
CJ7 Resto Project ---> http://www.jeepaholics.com/tech/cj7makeover/
OldJeepguy is offline   Reply With Quote
Old 09-05-2002, 05:53 PM   #4
Happypappy
Another nice thing about that particular swap is that the 304 you are removing will bring you pretty good bucks and make a guy doing a 258/304 swap verrrrrry happy as well !!
C. Lynn
Applications Engineer
Computerized Marine Diesel, IPS Systems
'06 Rubicon Unlimited
Happypappy is offline   Reply With Quote
Old 09-05-2002, 08:22 PM   #5
Bulletproofcj7
You will need to use a 360 fly wheel and not reuse the 304 fly wheel as these are externally balanced engines, and if i remember correctly the older amc v-8 heads had an oval exhaust port and the newer motors had the dog-leg exhaust ports. which ever you have, the port needs to match the manifold or header.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline   Reply With Quote
Old 09-05-2002, 09:31 PM   #6
OldJeepguy
1979 CJ7
Might as well install another pilot bushing in the crank - this is absolutely necessary if installing a 360 that was in front of an automatic. As bulletproof said, the flywheels are not even close to the same balancewise - I mistakenly sent my 304 flywheel to the machine shop to be balanced to the crank and it would have required 400 grams removed to do it! I sent them the 360 one and it was close (about 80 grams).
I had an RV2 cam grind done by a local shop - I wanted awesome bottom end and that's what I got - not really as streetable as I would like since it's all done by about 3500 rpm. Would be fine if I had an auto though...
Steve
jeep79cj@yahoo.com
Old 09-09-2002, 10:37 AM   #7
boredstiff
balancer too
If you haven't finished yet... I just did the same swap last year. Yes, I agree with the porting and the flywheel. You need to get a 360 harmonic balancer too. These are a bit different from the 304 to the 360, and in the case of the flywheel. Other than that... your ready to rock and roll!
boredstiff is offline   Reply With Quote
Old 10-01-2002, 03:26 PM   #8
rmclague
I know that you guys say that I would need a new flywheel , but I am running an automatic.
Will the flexplate interchange or are they different as well?
Thanks
Rob
Old 10-01-2002, 09:07 PM   #9
CSP
Yep the flexplates are different also. I have 304, 360, and 401 flexplates and none of them are even close when you look at the weight on the engine side of it.
Glock Forum
