304 or a 302? - JeepForum.com
post #1 of 12 Old 11-02-2011, 06:00 PM Thread Starter
Rogers123
1980 CJ7
304 or a 302?
Have just bought a 1980 Golden Hawk with a 258 and T-176 tranny. I want to go V-8. Looks like finding a 304 is slim...they won't take a 258 core. So...my next avenue is a 302 that will bolt up to my tranny....how sweet. Problem is I'm stuck with a 90k mile motor...anyone know the value of this 258. I had compression test on all cylinders...all 6 were 155...was told factory new was 160. I also want to sell the complete a/c....any value ideas here? I don't know for sure if I have to get another bell housing so engine may sell with it.
Rogers123 is offline
post #2 of 12 Old 11-03-2011, 07:33 AM
bkeese
1949 CJ3A
http://www.jeepforum.com/forum/f8/en...worth-1284726/
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #3 of 12 Old 11-03-2011, 07:52 AM
CJ7ROB
I was asking $600 for my old low compression slug of a motor..got $475 and another $100 for the bellhousing.
This means more funds to complete my 302
CJ7ROB is offline
post #4 of 12 Old 11-03-2011, 12:44 PM
SharonsRusty
1978 CJ7
Wanted : CJ 7 seat sliders
Sorry, I tried to put in classified section but I dont have enough posts My jeep needs them badly! Can someone help me out? Thanks, Sharon 1978 CJ7 Rusty is her name!
SharonsRusty is offline
post #5 of 12 Old 11-03-2011, 01:14 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i love my 360, eventually when i come across a 401 ill switch to that. cant go wrong with a sbf though, very solid motors. 302 has an excellent aftermarket too
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #6 of 12 Old 11-03-2011, 02:03 PM
Oktyabr
1977 CJ5
Love my 360 and the 304's I've had didn't make me wish for a 302 in any way, especially when it came to buying parts for it. That said, a solid 258? I'd build that one, maybe think about a 4.7 stroker or something.
Oktyabr is offline
post #7 of 12 Old 11-03-2011, 03:37 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
As is everything Jeep...what are you gonna use it for? 1st, the 304 bore/stroke vs the 302. So, the 304= 3.75 bore 3.44 stroke...302=4.00x3.00. Common knowlege says that the 304 will provide plenty of low end torque, and run outta steam at 4500 rpm depending on cam/intake etc. The 302 will have less torque, but plenty to move a CJ nicely. These things will also rev to the moon all day long, 6500 rpm(?).
Having said all this, I'm re, re-doing a 360, T-18, Comp Cams 292 Magnum(2500rmp-6500, HUGE, I know), Truck Avenger 770(jetted way down), and 4.10's on a glass CJ-7. I wanted a trail rider, mud puppy...and the boys, 7&11, wanted a street machine they could see out of and maybe win the stoplight drags! Compromises or disaster?
"Sometimes you can't see the forest through the bird in your hand-hutch".
hutch1200 is offline
post #8 of 12 Old 11-03-2011, 03:45 PM
hutch1200
hutch1200's Avatar
1979 CJ7
BTW, I've owned my 79 CJ& since '84. All my buds had 304's in all kind of Cj/J10's and Commandos. The Commando got a NAPA rebuild, w/all the upgrades, that lasted 2 years before blowing oil. He finally just yanked a 304 out of an Gremlin/Concord station wagon(5 door?). It still runs like a scalded ape. Must been made on a wednesday.
post #9 of 12 Old 11-03-2011, 05:40 PM
levergun
1979 CJ5
Not to go off topic but are you sure you want a magnum 292? I have the comp mutha thumpa 287 and it is pretty much to big for my 401, and it's 30 over with 11.5:1 compression. In a 360 it would be even worse. You probably will have no power and bog and stumble till you get at least to 2600,2700. And 0 bottom end at all. I wouldnt go that big in a 360. But that just my opinion.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #10 of 12 Old 11-03-2011, 06:04 PM
hutch1200
hutch1200's Avatar
1979 CJ7
Levergun, I agree 100%. I have the same comp ratio (BullTear forged). But I got the cam/carb for free in a deal for a set of highly modded 1970 dog-leg heads w/roller rockers. Maybe this is why the stuff was so cheap! Supposedly the heads were spec'd to an AMC R&D program way back then. Maybe 33's will help me? I've got a reverse tilt nose, so when I see how impractical it is, changing it to something rational shouldn't be to awful hard Thanks for the heads up about your camshaft, might go 1 step below yours.
post #11 of 12 Old 11-03-2011, 08:58 PM
levergun
1979 CJ5
I built a 360 for my brothers 79 cj7 a while back and it was nothing to crazy. We put the comp 270 in and it pulls hard right off idle. Doesn't have the insane pull my 287 has but a lot smoother lower power. Offroad the 287 I have sucks. Especially with a 3spd. My leg gets tired really quick. If you want something more aggressive than a 270 I would look at a comp 276 or 280. They probably will pull really hard from 2400-5500 and still allow you to be able to idle. A 292 will struggle to idle in a 360.
My pistons are speed pro by federal mogul with forged rods. I have cobra roller rockers too and I really like them. Valves and springs are comp stainless.
On topic, I wouldn't trade my amc for a ford, ok, maybe a 427. And I would go 360 over the 304 as usually cheaper to acquire and there is no replacement for displacement!!! But all in all I think the amc v8's are some of the best out there.
levergun is offline
post #12 of 12 Old 11-04-2011, 07:02 AM
CJunk
Are you sure you want to swap out stuff on an original golden hawk. I know its just a sticker package, but the value on those can only go up if you don't change the originality of it.
CJunk is offline
