302 swap anyone ? - JeepForum.com
post #1 of 8 Old 07-02-2010, 02:29 PM Thread Starter
seejayseven
302 swap anyone ?
can get a really good deal on a built 302 how hard is the swap, im pretty sure i have a t-177 tranny that has the ford pattern
seejayseven is offline
post #2 of 8 Old 07-02-2010, 02:47 PM
Coiz
1979 CJ7
You can look up my build, Exposed and Hackfabrication's right off the top of my head. I'm sure there are a few others. What is it out of? Carbureted or fuel injected?
Mine:
Exposed:
Hackfabrication:
Mike
Coiz is offline
post #3 of 8 Old 07-02-2010, 03:03 PM
jeffyjensen
1980 CJ5
im in the process of a 351w swap with the T176 got a complete motor for $35
new clutch disk or swap the tranny inout shaft
ford bellhousing instea of the amc one
mounts, linkege and wiring but thats any swap
the way i see it if you know ford swap in a ford if you know chevy (i'm sorry) swap that in. theres so much aftermarket stuff its pretty easyto swap drive trains
jeffyjensen is offline
post #4 of 8 Old 07-02-2010, 03:58 PM
Jim1611
Jim1611's Avatar
5.0 engine swap pictures Here's another link that you may find helpful too.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #5 of 8 Old 07-02-2010, 05:19 PM
Jim1611
Jim1611's Avatar
Here's another helpful link. Installing Ford V8 Engines in the Jeep CJ, 1980-1986
They have some pretty good info in there on installing a Ford engine in Jeeps, other years as well too.
My build thread
post #6 of 8 Old 07-02-2010, 07:10 PM Thread Starter
seejayseven
thanks for the info guys the one im looking at has edlebrock intake, carb, headers any more info on it will be appreciated ....im also getting a tranny ,i think i can use the bell housing flywheel clutch .ect ,if not let me know
post #7 of 8 Old 07-03-2010, 08:25 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Also check with 84MSRB, he's done the swap.
You'll need to be a bit more specific with the engine year, as Ford switched the flywheel from a 28oz to a 50oz imbalance in the early 80's (1981 comes to mind, but I'd have to research it again). They are available in either 157 tooth or 164 tooth.
Get a bellhousing from a late 70's -mid 80's F-Series or Bronco. IIRC, you can either get the 302/351 or 300 I6 bellhousing. Make certain it has the Ford 'butterfly' pattern on the trans side, as FoMoCo started moving to different transmissions in the later years. Ford also used a hydraulic clutch in some years, and you can get one with the external slave mount, if you want to go that route.
You will also need to get a starter 'matched' to the flywheel and bellhousing you use. With Ford, you must match the flywheel/bellhousing/starter.
Motor mounts can either be home fab'd or purchased from AA, TransDapt, MORE, et al. I used the MORE mounts, and had one a few issues to resolve.
Carb'd engine makes for a simple swap (although EFI isn't all that difficult).
Otherwise, take the weekend and start reading:
TOTW: Ford 302 engine swaps - Pirate4x4.Com Bulletin Board
"In the end...It's all Hack."
HackFabrication is offline
post #8 of 8 Old 07-04-2010, 01:46 PM
Havasu Living
1980 CJ7
Very true. Burned up a 94 starter in a 60's bellhouse. It bolted right up but the shaft was longer and stayed engaged to the flywheel. Only took 10 minutes to burn it up
80 CJ7 5.0 Dual Exhaust, T176, D300, D30 w/ true trac, AMC 20 w/ ARB 4.56 gears, York OBA, Hydroboost
Havasu Living is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 06:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-13-2009 12:36 AM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 08:31 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 08:49 PM
304 - 258 swap tbay7 Jeep CJ Forum 2 08-25-2004 09:38 AM
