302 ford fuel lines - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 302 ford fuel lines
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueComponent speaker deal for your dash - NalinMFG
Unread 08-18-2013, 06:57 PM   #1
petey156
1977 CJ5
302 ford fuel lines
Cleaning up my jeep, I have a 302 ford with the mechanical fuel pump. I know that I only need the fuel supply line, What should I do with my old return line..
Option 1. Use it
2. Delete it, then what should I do with the fitting on the sending unit where the return line goes.
petey156 is offline   Reply With Quote
Unread 08-18-2013, 07:47 PM   #2
superj
1987 YJ Wrangler
Just put a filter on the end of it and mount it high and you will never have the gas pump click off when pumping.
Slow ride, take it easy
superj is offline   Reply With Quote
Unread 08-19-2013, 12:42 AM   #3
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'd just use it as a return line. I figure the benefits of it helping to prevent vapor lock would be good reason to keep it. It's already there anyways!
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote
