3 speed auto on the column to 4? - JeepForum.com
post #1 of 4 Old 11-10-2013, 10:13 PM Thread Starter
dsfd722sts
1980 CJ7
Cj 3 speed auto on the column to 4?
what I want to know is, has anybody converted the cj7 (1980) 3 speed automatic column shifter to a 4 speed column shift column? or is there a replacement say out of a wagoner? doing the 4l60e swap and want to keep the column shifter. any ideas? it can't be as simple as mounting the 4 speed indicator?
also if anybody knows if they are still counting "hull" numbers?
dsfd722sts is offline
post #2 of 4 Old 11-20-2013, 07:52 PM
lar308
You maybe able to adapt parts from a chevy "G" van collum, or just use the complete collum. I don't remember the company name, but I installed a 700r4 in my 76 Laguna. There is a company that has a kit that replaced the detent plate in the shifter. If you google installing an orver drive trans into a camaro/firebird they may have something to help. Worst case, running what you have, you won't be able to manually shift into first gear. Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 3.5" springs, .5" boom shackles, dana 44's, 5.13's, Detroit locker's, 4340 axle shafts, 1 ton trod ends, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, M8274
lar308 is offline
post #3 of 4 Old 01-05-2014, 02:33 AM Thread Starter
dsfd722sts
1980 CJ7
thank you ron, ill try the "g" column.
post #4 of 4 Old 01-29-2014, 10:59 PM
REDnBLUES
1977 CJ7
Might try here. I am also doing this with a YJ column in my CJ.
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
