3 spd or a T176 behind a 360 - JeepForum.com
post #1 of 2 Old 04-17-2009, 01:08 AM Thread Starter
Johnyakimo1855
Ok now that my brain is pudding from sifting through all the threads. I figured I would just ask my own question. I am going to help a friend rebuild cj5 that has a 304 in it. After researching on here we are just going to yank it and rebuild a 360 with Howell tbi, edelbrock intake, cam, complete MSD, hi flow exhaust, valve job, and lower end rebuilt. He has the stock 3 speed in it. He drives on the highway a lot and does hunt in it. I figured it would make sense to go ahead while we had it out to put a T176 in it with a dana 300. My question is one: is it stronger that the 3 speed and will it give him better highway speeds at lower RPMs and two: will the existing drive shafts work? Any other pitfalls I need to be aware of?
Johnyakimo1855 is offline
post #2 of 2 Old 04-17-2009, 04:04 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The T-150 is actually the stronger of the two.
Top gear in both are 1:1 so there will be no difference in RPM on the highway.
The existing drive shafts will NOT work. I've done this swap.
The T-176/Dana300 has better gearing in my opinion but with a built up 360 I bet you won't have to downshift much to go up hills.
4 LOW and 1St gear in the T-176/300 combo is much lower than the T-150/20 combination.
The T-176/d300 is much lighter.
Should try to get the T-176/D300 skid pan as it will be a bolt in then. You would have to mess around with the T-150.d20 Skidpan to make the T-176/D300 fit.
The clutch is different. Even though the spline count is the same and same diameter there are slight differences in the ID between the T-150 and T-176 clutch shafts.
IF your not lucky the yokes will be swapable. The D20 had two different splinr counts on the yokes and only one will swap over to the Dana 300. Otherwise your stuck with two different U-joints on your drive shafts. One with straps and one with a u-bolt.
John Strenk is offline
need help with t176 jefflacy Jeep CJ Forum 6 02-06-2010 04:33 AM
Should I buy this T176? NelsonATC Jeep CJ Forum 12 12-03-2009 11:49 AM
T176 & 300 in Cj5 starky Jeep CJ Forum 4 05-30-2007 08:11 AM
What came with the T176? JOKER4INK Jeep CJ Forum 2 05-01-2006 11:36 PM
t176 vs. T5 for a CJ Hibbitz Jeep CJ Forum 27 10-08-2005 01:52 PM
