Quantcast 3" Black Diamond + Warrior 1 1/2" Lift Shackles - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 3" Black Diamond + Warrior 1 1/2" Lift Shackles
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-08-2008, 09:37 PM   #1
sweetguardian00
1946 CJ2A
i just bought myself a 3" BDS kit with WP lift shackles to put on my 83 (stock), what else do i need, should i need, want to need, anything to need so i can get it up and going soon w/o snags
also, is a t-5 stronger than a T-4?
1946 CJ-2A 225/T90/D18
1966 CJ-5 231/T86/D18
1986 CJ-7 258/TF999/D300
1984 C-10 6.2/SM465
Yeah it's a Diesel
sweetguardian00 is offline   Reply With Quote
Old 05-09-2008, 05:02 PM   #2
sweetguardian00
1946 CJ2A
anyone at all?
1984 C-10 6.2/SM465
Yeah it's a Diesel
Old 05-09-2008, 05:27 PM   #3
Bard
I would get a dropped pitman arm as well. make sure you adjust your tierod and drag link ends after install. Get all the right tools, plan for the best, prepare for the worst. Might want to get new u-bolts for the front and rear ends, change your driveshaft u-joints to new ones, get some new bolts for the shackles, rent some acetelyne torches, start PBing every bolt you plan to touch.
T4 and T5 are the same tranny, just 1 more gear, same weak to medium transmission, but better than a SR4. I presonally like the T5 for the OD, but that is me.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Old 05-09-2008, 06:23 PM   #4
78treehugger
Lost and Not Found
1980 CJ7
Instead of doing a drop pitman arm, I would go ahead and do a tierod flip. Around the same price and plus you gain clearance for your tierod and drag link. Not sure if this is going on a CJ5 or CJ7 but you may need to modify your driveline. Meaning t-case drop or have your driveshafts modified. I have the Black Diamond 3" lift on my 78 CJ 5. My rear driveshaft is a little steep but I don't have any vibration and I have flexed it until I was floating 2 tires. So it seems alright. If it's on a CJ7 you may be able to get by without any mods. Not sure. I have stock length shackles as well. The kit should have came with new u-bolts and all new bushings.
Grinder ( or something to cut ubolts off with)
Impact
penetrating oil
at least 2 jacks stands, prefer 4
jack
some friends (goes easier)
Good luck let us know.
78treehugger is offline   Reply With Quote
Old 05-10-2008, 05:15 AM   #5
bjf498
1983 CJ7
why buy a bds 3" kit just to put 1" shackles on it and make it a 4" kit?
why not just buy the 4" lift kit?
also BDS and black diamond are not the same.
http://www.bds-suspension.com/
http://www.superlift.com/suspension/black-diamond.asp
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline   Reply With Quote
Glock Forum
