2inch, 4inch?... how can I measure my Cjs lift height? - JeepForum.com
post #1 of 16 Old 10-26-2010, 09:19 AM Thread Starter
LordSul
1975 CJ5
Hey there,
Beware noob question!
My CJ has 33" Mudzilla, and had the lift before I bought it, so I really dont know what my lift height is. Im planning to get new shocks thats the reason I need to know my lift.
Thanks in advance
LordSul is offline
post #2 of 16 Old 10-26-2010, 10:27 AM
CJ8Extreme
1983 CJ7
Pics would be great here. You can run 33's on almost any amount of lift, now you can't flex them on 1" of lift etc lol. How is your spacing of the tire in the fender well, is there a fairly large gap there? Without pics it would be hard to say. Noramal lift for 33's = 4 inches, however with all the types of lifts out there you have to look closely at what you have. 2 inch lift and 2 inch body lift would cause you to need a smaller shock than just having a plain ole' 4 inch suspension lift etc, etc, etc.
CJ8Extreme is offline
post #3 of 16 Old 10-26-2010, 10:59 AM
JoonHoss
2011 JK Wrangler
also, you'd be better off ordering your shocks by the actual measurement, than a guessed lift height.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #4 of 16 Old 10-26-2010, 12:35 PM
gojeepin
1983 CJ7
X2... but if you go to most places like Autozone or Advance Auto, they'll try to look it up on the computer by asking you what vehicle it's for.
For custom work, you'll have to tell the kid behind the counter that they've got a catalog with shocks by compressed/extended length and the type of ends needed.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 16 Old 10-27-2010, 02:48 AM Thread Starter
LordSul
1975 CJ5
Thanks, here are some pics, hope it gives some ideas.
LordSul is offline
post #6 of 16 Old 10-28-2010, 04:16 PM
CJay7
That looks to be at least a 4 inch lift with a good amount of that coming from a shackle lift.
'85 CJ-7 - 258 bored .030 w/ mid level cam, 4.0 head, Clifford intake and header, Weber 38, TFI w/ MSD 6, Black Diamond 3" lift, Daystar 1/2" lift shackles, 33x12.5 Goodyear Duratracs with stock 3.31 gears.
CJay7 is offline
post #7 of 16 Old 10-28-2010, 04:32 PM
Jeepican
1976 CJ5
Could be 3" ... 2".... hard to tell.... i would yank those shackles out..... might just take your shocks off and measure? Could be all the glare from that shine......throw a little mud on it...
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #8 of 16 Old 10-28-2010, 06:01 PM
petey156
1977 CJ5
looks good new shocks are not going to make it ride much better.... looks like a 2 inch spring lift and a 2 inch shackle lift.. I would take those shackles off and go back to a stock one
petey156 is offline
post #9 of 16 Old 10-28-2010, 06:07 PM
paraman72
x 2 for me...
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #10 of 16 Old 10-29-2010, 11:09 AM Thread Starter
LordSul
1975 CJ5
If I take the shackles off and use stock ones, would I need to increase my spring lift, or the decrease in height would be insignificant? or unnecessary even?
LordSul is offline
post #11 of 16 Old 10-29-2010, 12:03 PM
Chewtoy
1976 CJ5
Stock shackles for a CJ are 3" center of the bolt hole to center of the other bolt hole. You really don't want to go more than 1" longer due to all the steering issues that really long shackels introduce on a street driven rig.
Because shackles are only on one end of the spring, the lift they give you = 1/2 of the extra length beyond the 3" stock. ie a 4" shackle will give you 1/2" of lift, a 5" shackle will give you 1" of lift.
I would suggest you get 4" shackle. This will make sure they are long enough to work properly with your lift springs, help stableize your steering, and still give you 1/2" of lift.
You should clear the 33s just fine for street driving, just don't hit the curbs too fast ;-) you have not mentioned what kind of off road you want to do if any, so we can't really give you much advise of how much more spring lift you might need.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #12 of 16 Old 10-29-2010, 12:22 PM Thread Starter
LordSul
1975 CJ5
Thanks for the replies,
Helpful tips chewtoy
This is the maximum Im going off the road, so not a big deal I suppose.
YouTube - Our first off road climbing, Cyprus.
LordSul is offline
post #13 of 16 Old 10-29-2010, 12:30 PM
Chewtoy
1976 CJ5
Oh yeah. if you find that you need just a little bit more, you can always throw a 1" body lift on it and be in good shape. Welcome to the addiction.
Chewtoy is offline
post #14 of 16 Old 05-13-2011, 05:24 AM Thread Starter
LordSul
1975 CJ5
It has been long since the last post,
I decided on ordering a 2.5" skyjacker lift kit, new shackles, and 1 or 2" body lift.
I broke my leafs 2 times since this thread, so Im doing this the right way this time.
So Im brainstorming, please let me know you thoughts
With 1" body lift plus the 2.5" lift kit, clearance would be just enough for the 33 tires I have. 2" body lift would be enough, but would have some downsides.
If I could afford a 4" kit with tc lowering and long brake lines, maybe it would be the best, but I know I definitely CANT afford an extra CV shaft. Would I need it if I had TC lowered?
So which one would you say is the most cost - effective,
1. 2.5" susp lift + 1" body lift + 1/2 shackle lift (my favorite)
2. 2.5" susp lift + 2" body lift + stock shackles
3. 4" susp lift + stock body + stock shackles + No CV shaft + TC lowering + extended brake lines
Im going to start a new project diary after I decide which one to go on.
Thank you all.....ride safe!
LordSul is offline
post #15 of 16 Old 05-13-2011, 06:06 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I have the first one (Your favorite) on my CJ5.
I had to do the tranny drop on mine cause the CJ5 is so short.
I still needed to get extended brake lines anyway, mainly for the rear axle, the brake hose actually stopped the axle from dropping far enough.
I'm also running 33 X 12.5 on 10" rims on the CJ5 narrow track axles. If I had the wide track axle, it probably would not clear the fender lip. As it is on NT axles, they fit nice when flexing.
John Strenk is offline
JC Whitney lift kit sale 4inch rough Country $310 neals80 Jeep CJ Forum 7 07-05-2009 11:46 AM
35 inch tires with 4inch lift? Demo Jeep CJ Forum 10 06-30-2009 08:42 AM
Need Help With 4wd 4inch Sus. Lift twokids Jeep CJ Forum 1 05-26-2008 02:37 PM
Lift Height TUPPERCJ7 Jeep CJ Forum 1 11-16-2007 03:32 PM
cj 7 lift height outdoordad@comc Jeep CJ Forum 2 02-17-2006 12:11 PM
