285 Coolant direction - JeepForum.com
post #1 of 9 Old 01-17-2010, 05:12 PM Thread Starter
Boosted98gsx
Which way does the coolant flow in these engines? top to bottom on the radiator, or bottom to top? Need to know which way the thermostat needs to be installed. Just did a head job on a 285 and it overheated on the first startup. Trying to eliminate variables here.
Thanks
Boosted98gsx is offline
post #2 of 9 Old 01-17-2010, 05:54 PM
wrongway92407
wrongway92407's Avatar
The little point faces outward. in at the top out at the bottom
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #3 of 9 Old 01-17-2010, 06:05 PM Thread Starter
Boosted98gsx
So just to be redundant, coolant comes into the radiator at the top, and exits the radiator at the bottom?
post #4 of 9 Old 01-17-2010, 06:10 PM
VACJ7
VACJ7's Avatar
You said basically the sames thing as Wrongway. It flows out of the engine through the thermostat and into the radiator at the top. Out of the rad at the bottom and into the engine.
VACJ7 is offline
post #5 of 9 Old 01-17-2010, 06:12 PM Thread Starter
Boosted98gsx
Okay thank you, I just wanted to make sure that it was how it should be via thermal engineering. Still need to figure out why it's overheating. I guess it's time for a compression check :-\
post #6 of 9 Old 01-17-2010, 11:10 PM
wrongway92407
Ever notice that lower radiator hoses are usually heavier and thicker and some have a spring inside, that's so they won't collapse from the suction of the w/p
Wrongway
My fleet:
post #7 of 9 Old 01-18-2010, 06:24 AM
Mike Romain
The heads can be difficult to get all the air out of sometimes.
Mike
Mike Romain is offline
post #8 of 9 Old 01-18-2010, 09:13 AM
mtbtweety
mtbtweety's Avatar
1982 CJ8
only a few vehicles flow bottom to top (90s Camaros and maybe Vettes?). Most flow top to bottom to take advantage of gravity in the radiator.
mtbtweety is offline
post #9 of 9 Old 01-18-2010, 09:54 AM
wrongway92407
After reading mikes post, I went back to the beginning and you didn't say that you had a over heating problem. That's a different story. we need specifics. Did this happen all at once, did you change something and this is a result, is it really hot, or does the gauge say it's hot!
Wrongway
My fleet:
Coolant flow direction to heater core? Havasu Living Jeep CJ Forum 4 02-04-2010 06:53 AM
Started without coolant, now coolant in oil. Blown head gasket? bkkrehbiel Jeep CJ Forum 6 12-26-2009 07:22 AM
Still over heating: no coolant flow, boiling coolant CJATE Jeep CJ Forum 45 07-15-2009 04:24 PM
I need SOA direction, please Skerr Jeep CJ Forum 13 10-15-2008 05:44 PM
86 cj-7 laredo, need some direction rusty86cj7 Jeep CJ Forum 1 06-23-2003 09:21 AM
