285 Carburetor Rebuild - JeepForum.com
post #1 of 6 Old 02-03-2010, 03:43 PM Thread Starter
budacj7
Junior Member
1982 CJ7
My carb. needs to be rebuilt. I don't think it has ever been.
I bought the rebuild kit at Autozone. I've rebuilt them before but it's been awhile any advice or great threads on tips/tricks on the 258 carb rebuild?
Thanks!
budacj7 is offline
post #2 of 6 Old 02-03-2010, 03:58 PM
pcg7384
1981 CJ7
I just did this. Here's a link to the post I submitted when I did...
http://www.jeepforum.com/forum/f8/wi...ebuild-949381/
Good luck, put everything back in the same place you found it. I managed to take the carb base plate off and put it on wrong, thus negating my idle mixture screws. Still have to fix that one...Jeep runs great though!!!
Phil
pcg7384 is offline
post #3 of 6 Old 02-03-2010, 07:19 PM
Matt_G
1979 CJ5
i did mine a couple weeks ago, it saved me about $300 cuz i was about to buy a new one. there is one spring i left out but it hasn't affected me much, will have to get around to putting it back in. it was all real simple for me, mainly because i got one of those trays with different compartments (fishing lure box?), so i kept all parts from one section together. i think it always helps to do that.
Matt_G is offline
post #4 of 6 Old 02-04-2010, 08:51 AM
Mike Romain
Just a couple quick things.
Count the turns needed to seat the mix screws first.
The little chunk of U shaped gas line between the filter and carb can hold an amazing amount of crud and when this line gets tightened on, you have to use two wrenches. One to hold the carb fitting from moving because it is the float needle setting and the other to turn the gas line fitting.
Mike
Mike Romain is offline
post #5 of 6 Old 02-04-2010, 09:00 AM
pcg7384
1981 CJ7
Just an update. Took the carb off last night and checked the base plate. Looked correct (with the notches on the top of the plate). I just rotated it 180 degrees because it looked the same either way I put it back on and I figured it wouldn't hurt. Fixed my idle mixture screws issue.
Don't mess with the floats. I did and caused me a world of problems until I got them back to specs. It's easy to do and I'm glad I did it. I won't be buying a new carb anytime soon.
I used little paper muffin cups to hold the individual parts while I was cleaning the big pieces. I also got a cheap handheld strainer from wal-mart and used that to soak the little pieces in so I wouldn't have to stick my fingers in the carb cleaner.
Phil
pcg7384 is offline
post #6 of 6 Old 02-04-2010, 02:29 PM
ricewt
ricewt's Avatar
1979 CJ7
Are you rebuilding the stock carb? If so, I know you already have the rebuild kit, but this would be a great time to do an amazing carb upgrade.
A junk yard ford motorcraft 2100 2 barrel with a 1.08 venturi size (stamped on the side) is a must in my opinion for the 258. They are very common. This carb was used for 20-30 years if I recall.
It takes a carb from a yard for around 20.00, rebuild kit for around 25.00? and the adapter plate from summit racing for 12.00.
Easy easy to rebuild, bolts right up, lots more power, in my opinion an all around better carb.
Lots and lots of writeups on this process on the internet if you are interested or just ask. I did it about 3 mo ago. Good luck!
79 CJ7 stock with 258 / MC2150 carb
ricewt is online now
304 carburetor jeepcj304 Jeep CJ Forum 7 01-13-2012 10:15 AM
Best Carburetor for AMC 360? Bobby9821 Jeep CJ Forum 8 08-15-2011 10:05 PM
About Carburetor CJ 86 CJ-Dan86 Jeep CJ Forum 6 01-20-2010 06:08 PM
Best Carburetor for 304??? Flange Jeep CJ Forum 5 03-19-2009 11:59 AM
Carburetor ID crosbike3688 Jeep CJ Forum 2 10-06-2007 07:07 PM
