258 YF carb help - JeepForum.com
post #1 of 2 Old 05-03-2010, 08:01 PM Thread Starter
ozzieb
1977 CJ5
258 YF carb help
i have a 258 with a carter YF carb on. when the motor idles its rought and the rpm goes up and down. but when i press on the little rod that its by the eletric choke body it runs perfect , but when i let go it goes back to runing bad. what is the problem , can someone help?
ozzieb is offline
post #2 of 2 Old 05-03-2010, 09:46 PM
TowMaster
make it so the little rod your pressing on stays in that position?
what year?
NightCrew #125
Why don't they have braille at drive-thru's?
TowMaster is offline
304 Backfires through carb, new carb/intake BigAl1979CJ Jeep CJ Forum 5 03-16-2010 09:18 PM
Carb return line leaking.........too much pressure? And other carb questions. Blthomas Jeep CJ Forum 0 06-01-2009 10:04 PM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 07:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 06:34 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 01:34 PM
