258 valve cover will not seal - JeepForum.com
post #1 of 11 Old 05-15-2011, 10:12 PM Thread Starter
cdmiller2
1981 CJ5
My I recently had my aluminum valve cover off, I reused the old gasket and it leaked, someone at my work suggested Hi-temp rtv, so I tryed that, it lasted about two drives before it started leaking. I ordered a new gasket tonight, does anyone know the proper bolt length for a clifford valve cover?
cdmiller2 is offline
post #2 of 11 Old 05-15-2011, 10:24 PM
JaySch
Mine ia doing the same thing. Leaking bad!
JaySch is offline
post #3 of 11 Old 05-15-2011, 10:35 PM
Coiz
1979 CJ7
I had an aluminum Clifford 6=8 that kept leaking in college. We took it off and the straight edge told us it was warped by over .040". The metal shop professor milled the surface flat and it never leaked again.
Mike
Coiz is offline
post #4 of 11 Old 05-15-2011, 10:36 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Place thin coat HT RTV on cover and head, allow to setup for about 10 mins. Then place NEW gasket on head, place valve cover on. Start in the middle both sides and only hand tighten,working your way outward on both sides. Let set about 10 mins then working both sides from middle to outside and torque to spec.Has never failed me yet
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 11 Old 05-15-2011, 10:40 PM
Coiz
1979 CJ7
^^^ I second SlikRic except I wait 12-24 hours between hand tight and final torque.
Mike
Coiz is offline
post #6 of 11 Old 05-16-2011, 10:04 AM
littlebuddie
1980 CJ7
What kind of gasket are you using?
1980 CJ-7 258 Dana 300, SR-4 Trans, Basically Stock Except One Piece Rear Axles, Weber Carburetor.
O\lllll/O
[]=O=[]
littlebuddie is offline
post #7 of 11 Old 05-16-2011, 11:11 AM Thread Starter
cdmiller2
1981 CJ5
The new one I ordered is a factory style rubber one
post #8 of 11 Old 05-16-2011, 11:48 AM
littlebuddie
1980 CJ7
Can you give us some information about your CJ..................fill in your signature with basic information so we don't have to ask a lot of questions about what you are working on. Engine, trans, carb, etc.
O\lllll/O
[]=O=[]
post #9 of 11 Old 05-17-2011, 10:12 AM
wm69
Shouldn't the Clifford valve cover be cork? Mine is.
wm69 is offline
post #10 of 11 Old 05-17-2011, 12:34 PM
littlebuddie
1980 CJ7
I was gonna' say..............but we don't really know what's being worked on here.
O\lllll/O
[]=O=[]
post #11 of 11 Old 05-17-2011, 12:58 PM
pspradlin2
1983 CJ7
It can be easy to over tighten on the valve cover. I went trough 2 gasket last year before I did the RTV along with a new gasket and only hand tight, set for 12 hours, then torque to spec. stopped leaking....as for the bolt length i wouldn't know.
pspradlin2 is offline
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 08:35 PM
PCV Valve install in 4.0 Valve Cover? VaCJ79 Jeep CJ Forum 5 10-24-2010 12:14 PM
PCV Valve location/Valve cover replacement jobst Jeep CJ Forum 2 03-28-2010 02:53 PM
PCV valve and leaking valve cover hole crrushing Jeep CJ Forum 2 02-08-2010 06:44 AM
Valve Cover/seal question DaGREEK Jeep CJ Forum 13 08-20-2004 07:10 PM
