258 valve cover gasket - JeepForum.com
 6Likes
post #1 of 17 Old 06-19-2017, 02:37 PM Thread Starter
rmy
So after owning a CJ7 since 1990, I can finally say I have won the leaking valve cover war. You may be asking how.
1) aluminum valve cover 2) using permatex #2 non-hardening sealant, place clean vc upside down, attach gasket and allow to cure 12 hours; use bolts through holes to ensure alignment. 3) attach valve cover to head with same sealant; do not over torque 4) allow to dry 24 hours before driving.
Been leak free for a year now. GL
Sent from my iPad using Tapatalk Pro
258, STJP and Ctknorr like this.
rmy is offline
post #2 of 17 Old 06-19-2017, 07:07 PM
STJP
STJP's Avatar
I'm thinking I might just weld mine.
STJP is offline
post #3 of 17 Old 06-20-2017, 05:35 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
A heavy bead of the Right Stuff, with no gasket, works for me.
Matt
pedal2themetai likes this.
Matt1981CJ7 is offline
post #4 of 17 Old 06-20-2017, 10:33 AM
Clemmohb
You Are lucky .Go to 2.5 l and the only valve covers I can find are plastic like the original equipment
Sent from my SM-G950U using Tapatalk
Clemmohb is offline
post #5 of 17 Old 06-20-2017, 01:56 PM
258
Did you use the CORK or RUBBER gasket?
258 is offline
post #6 of 17 Old 06-20-2017, 02:19 PM Thread Starter
rmy
Special thicker cork gasket made for the aluminum valve cover. Bought from 4WD.com.
rmy is offline
post #7 of 17 Old 06-20-2017, 03:32 PM
whollsee
1982 CJ7
Fel Pro - neoprene with thin metal core. No sealant required. Totally reusable. I use with alu vc.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #8 of 17 Old 06-20-2017, 04:04 PM
258
Cj
You have that Fel Pro part #? I have the Omi aluminum vc.
258 is offline
post #9 of 17 Old 06-21-2017, 03:47 AM
whollsee
1982 CJ7
VS50244R. Mine is an '85 head. Please double check that PN [If you aren't spooked by the $48 RRP!!!]. Need to make sure it is the "sponge-lam" version. I think that PN was originally a cork-rubber compound and there is still old stock floating around.
whollsee is offline
post #10 of 17 Old 06-21-2017, 04:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
After flattening and straightening the lip my stamped steel valve cover, I have it successfully sealed it now for 5 years. Most people just torque the heck out of the screws and bend the lip and crush the gasket. If you can flatten it out and use the proper torque, you can get t to seal properly again. You can also get "washer" that are wider that helps distribute the torque.
John Strenk is online now
post #11 of 17 Old 07-13-2017, 10:34 PM
Renegade82
1982 CJ7
The Fel-Pro vs50244r is a cork-lam gasket with a metal center. I don't think these are considered "reusable". The DryPlus ones are but they're silicone and not available for the 258. They show one for an 86 but I bought one and it's not right. I think it's for the 242 (4.0) sixes they put in wranglers.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #12 of 17 Old 07-13-2017, 11:16 PM
whollsee
1982 CJ7
Sponge-lam version is re-useable. My understanding is cork-lam was older version. . I've used both. Fel pro site is not helpful at all I have found in the past. I think the version you purchased should have stated 1987-95 compat. as a case in point. Just to confuse us various vendors have cork lam and sponge lam mentioned within the same product description eg . O'Reillys...
Found this recently...
http://www.militaryjeepers.com/commu...58-valve-cover
Renegade82 and 258 like this.
whollsee is offline
post #13 of 17 Old 07-13-2017, 11:17 PM
258
Cj
Got my eye on a VS50244 but the "C" (cork). Maybe I'll get the "R" (rubber). I have the cork on now, just couldn't remember the part number for the aluminum valve cover. Anyway, the way I installed it previously was to seal it to the valve cover itself, then sealed it to the head. It has never leaked. The only reason I need to remove it is to check for the cause of a slight ticking. It driving me nuts. I've managed to reduce it quite a bit but I guess since I know the engine well, I hear it clearly. Others think I'm nuts. lol. Not looking forward to it for fear I may discover more than I want to.
258 is offline
post #14 of 17 Old 07-13-2017, 11:25 PM
258
Cj
Great Link! . . . is the '710' cap better than the plastic one that came with the aluminum valve cover? Mine always leaked around base but I put an 'O' seal around that base and it has never leaked since. If it's better, maybe I'll switch.
258 is offline
post #15 of 17 Old 07-14-2017, 01:01 AM
Bigmaaty
1979 CJ7
I used these bolts:https://www.albanycountyfasteners.co...m?1=1&CartID=0
And this gasket from Rockauto:FEL-PRO*VS50522T*PermaDryPlus®*Info
w/Aluminum valve cover; PermaDryPlus®
This was on my '89 YJ, not my CJ but should be the same for later models with the alum. valve cover. Was meticulous in cleaning both mating surfaces. Installed with no RTV. Carefully torqued all the bolts as spec'd in the recommended pattern with blue Loctite. It has been about 4 months and so far bone dry all the way around. Seemed crazy at the time to spend $30 on a gasket but had seen it recommended here and I think it was worth it. The washer head bolts were a good addition in my opinion as mentioned by John above. Hope braggin' on it doesn't jinx me, so far so good.
Bigmaaty is offline
