#1 | |
258 Timing cover problem
I'm building an 89 258 with a 4.0 head to go into my 86 CJ. A machine shop assembled the short block for me, and with the new timing set, the timing cover doesn't fit. Does anyone have experience with this or know how I can work around it?
Ken
#2 |
the harmonic ballancer is off correct??
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#3 |
There are two timing covers for the 258. One is a thin one (older), and the other is thicker (newer one). Found this out when I bought a remanufactured engine. The engine I got was origionally a 1984, going into a 1986 CJ7. Discovered that my accessory brackets (alternator etc.) would'nt fit. Ended up buying a new timing cover. Could be your problem!
Beer is the answer - it doesn't matter what the question is! '86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift. '04 TJ Sahara. '00 TJ Sahara. |
#4 |
Uh, yeah, the harmonic balancer is off. I'm not sure which of the 2 different timing covers I have. As far as I know, it's the factory timing cover off of the 1989 YJ 258. I'd imagine, in this case, that the thinner one might be the one I'm looking for?
#5 |
is it the one that originally came off the engine??did you give the machine shop the shortblock to tear down and rebuild?maybe they switched them up...
#6 |
I disassembled the engine and kept the timing cover. The new timing set from a master rebuild kit appears to be slightly wider than the original. Unfortunately, I chucked the original timing set into a dumpster, so I can't upload pictures to compare the two.
#7 |
I just found this....http://www.trailquest.com/DriveTrain/Engine_AMC_258.shtmllook at the listing for 39...that may be your problem....
and this copied from a racing amc page for i6's.. Timing Chain: Cloyes offers a “True Roller” dual-roller timing chain and gear set for the AMC six. The crank gear has three keyways, allowing you to advance or retard the cam by 2 degrees. This chain and gear set is superior to all I have seen, and after thousands of street miles and hundreds of ¼ mile passes the chain is still as tight as the day I bought it. A replacement chain is available for this set. The stock oil slinger may not be used with a dual-roller timing chain set.
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] Last edited by Mr.Crowley; 01-01-2007 at 08:10 PM.. |
#8 |
Look at my previous post. The old timing cover (much thinner) is part #53005768. The newer models had a thicker cover, model #53005769. The part number is on the front of the cover. If you have a '89 engine you need the newer one. Had a similar problem putting a remanufactured engine in my '86 CJ7.
#9 |
I'm looking into it now.....think I'm gonna buy that new timing cover and see if it fits. CJ Chet and scrambeled, thanks for your help so far.
Ken |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
