Quantcast 258 squeals - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 258 squeals
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 01-20-2009, 05:25 AM   #1
JIBTEXHNKA
1987 YJ Wrangler
258 squeals
...and it's annoying the crap out of me. it's a squeaking/squealing sound, very high-pitched.
it started today on the drive to work. i can't determine where exactly it's coming from, but it's somewhere near the middle/rear of the engine. possibly near the carb (original carter).
it doesn't change with higher RPMs, although it gets a bit lower in pitch when the engine is under load (accelerating/going up a hill) and i think it goes away completely while accelerating hard but at that point the noise from the engine would drown it out anyway, so i can't be entirely sure.
it's LOUD. and besides making me envy the deaf it's probably something i should fix sooner, rather than later.
any ideas?
JIBTEXHNKA is offline   Reply With Quote
Old 01-20-2009, 07:07 PM   #2
JIBTEXHNKA
1987 YJ Wrangler
...anyone?
Old 01-20-2009, 07:12 PM   #3
jksull
Vacuum leaks like thru a gasket or split hose will make a squeal like you described
jksull is offline   Reply With Quote
Old 01-21-2009, 08:45 PM   #4
CJhollic
1980 CJ7
A ccouple of carb mounting bolts worked loose on my boat carb and it made a loud squeal. The gasket was acting like a reed in a musical instrument. Also check belts to make sure they are good.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline   Reply With Quote
Old 01-21-2009, 09:50 PM   #5
80cj
80cj's Avatar
1980 CJ5
I had that problem with mine a couple years ago. Found out the manifold bolts were all lose. 10 minutes with a torque wrench fixed it.
80cj is offline   Reply With Quote
Old 01-22-2009, 11:26 PM   #6
JIBTEXHNKA
1987 YJ Wrangler
thanks, i'll check both of those. that's the general area the noise is coming from so i hope that's it.
Old 01-23-2009, 06:32 AM   #7
sgtbookie
1982 CJ5
Are you sure it is coming from under the hood? I had something similar, and it ended up being the Speedo Cable squeaking.
- 1982 CJ5 -
AMC 258 TeamRushed, MC2100, T-176, Dana 300, Goodyear AT 31's, AMC AM Radio, SuperTop, Tuffy Stereo Console , Black Diamond AT Shocks , CJ Draw Bar, Herculiner
The secret to a jeep, especially a cj, is you can't panic. - Mike
sgtbookie is offline   Reply With Quote
Old 01-28-2009, 07:28 PM   #8
JIBTEXHNKA
1987 YJ Wrangler
it's coming from that general area... when i open the hood it gets louder. i still can't pinpoint where exactly it's coming from though.
in other news, me speedometer DID stop working a few days before this happened...
Old 07-13-2009, 09:30 AM   #9
Jimd0313
1983 CJ7
Any update on this? I have the same noise happening, wonder if you ever got it resolved?
Jimd0313 is offline   Reply With Quote
Old 07-13-2009, 04:20 PM   #10
JIBTEXHNKA
1987 YJ Wrangler
it's a leak in the intake manifold gasket. i tried to put some RTV on there but it didn't work too well... replacing the gasket would do it. hope that helps.
Old 07-13-2009, 04:32 PM   #11
Fjguercio
1978 CJ7
opps double click.
Fjguercio is offline   Reply With Quote
Old 07-13-2009, 04:37 PM   #12
Fjguercio
1978 CJ7
should not use RTV where there is GAS service. The RTV will not hold up. ON the intake use a premium gasket set like a felpro and get the correct one for the aluminum or cast iron type manifolds.
The I6 long manifolds are known for loosening up and leaking. Start in the center and work you way out in a circular pattern. Just snug all up by hand, then snug with sockets. Then 7, 10, 15, 20, till you reach 23 ft#. After you have run the jeep several times and had some temp cycles. Retorque them again. They like to warp, loosen up, and not seat right. Torque wrench and this process is the only way to go. Ck the manifolds and carb every couple of years or so.
Hope that helps,
Fred
Old 07-13-2009, 05:04 PM   #13
swatson454
In Jesus, I trust!
swatson454's Avatar
1983 CJ7
2X on retorquing. Do it again after a week or so, too. I waited about two weeks before doing it the third time and a few of them were starting to loosen up. My squealing was coming from the intake manifold as well.
swatson454 is offline   Reply With Quote
Glock Forum
