258 Smoking - JeepForum.com
post #1 of 12 Old 03-17-2009, 05:20 AM Thread Starter
jmdkb12
258 Smoking
I just figured out my wiring issue and now that I can keep it running it is smoking real bad. I havent adjusted any of the mixture screws yet, could that be the problem? Could it be the EGR Valve is bad? Also I havent got all the vacum lines hooked up, which brings me to my next question. I dont have the stock air intake for the 258 so what is the best way to run vacuum lines off the valve cover and off the carb? The reason I ask is because I have seen many off diagrams of vacuum lines on here and they all are showing them with the stock breather. If a picture is needed let me know.
Thanks
jmdkb12 is offline
post #2 of 12 Old 03-17-2009, 06:33 AM
Mike Romain
It runs....
You might want to give us a just a little hint as to the flavor and year of the engine and if you need emissions or not....
Mike
Mike Romain is offline
post #3 of 12 Old 03-17-2009, 09:31 AM Thread Starter
jmdkb12
sorry the year is a 79 on the 258 I think I might have been running it a little to rich. But yeah it runs. My main concern is the vacuum lines how they can be ran or bypassed without the stock breather? My next question and this might have to go into a new thread. On my timing the noch on the flywheel is at about 11 or 1130, what to I need to do to get it over to the correct location where the timing marks are?
Thanks
jmdkb12 is offline
post #4 of 12 Old 03-17-2009, 10:00 AM
BioTex
1979 CJ7
Not sure I follow what you are asking on the timing marks. If you are using a timing gun, and you rotate the distributor, the maks will align. You want the scribed line on the harmonic balancer to align with the mark on the timing cover. Use the mark labeled for 6 to 8 deg. to start with once you get the timing correct at idle with no vacuum leaks, then you can adjust the mixture screws. Bottom out the screws ever so slightly so you don't damage the seats then back them both out 1 1/2 turns if 2 bbl carb. if single, then there is only one screw. This will get you in the ball park. Set your timing with the vacuum line to the distributor unplugged and capped (so no leaks). This will be called initial timing.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #5 of 12 Old 03-17-2009, 10:24 AM
Mike Romain
Thanks
Which carb do you have on it?
Did you have the distributor out? If so it needs to be rotated to get the timing mark to come over on the balancer.
Mike
post #6 of 12 Old 03-17-2009, 10:31 AM
BioTex
1979 CJ7
I wish we had a sticky for how to set timing and adjust mixture. This gets asked a lot.
Currently:
BioTex is offline
post #7 of 12 Old 03-19-2009, 08:01 PM Thread Starter
jmdkb12
Ill give the vacuum on the dist off a try I didnt do that.
jmdkb12 is offline
post #8 of 12 Old 03-20-2009, 06:41 AM
CrazyHorse6
1979 CJ7
If you are in Newnan, GA, you have NO EMISSIONS inspections on a '79. Also, and I might have missed it, but what color smoke? Blue, black or white?
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #9 of 12 Old 03-20-2009, 08:13 PM Thread Starter
jmdkb12
it was white im pretty sure
jmdkb12 is offline
post #10 of 12 Old 03-22-2009, 09:20 AM
CrazyHorse6
1979 CJ7
If it is cloud white it may indicate coolant or water getting into the combustion mix - has the coolant level been going down?
post #11 of 12 Old 03-22-2009, 09:25 AM
Mike Romain
Condensation in the exhaust system can blow a bit of white until it heats all the way up, especially if there were a few short start ups.
Mike
post #12 of 12 Old 03-22-2009, 12:30 PM Thread Starter
jmdkb12
The thick white smoke has gone away since I adjusted the mixture, and I dont think that the coolant has gone way down if at all like Mike said I think that it is the condensation because I did have some short starts.
jmdkb12 is offline
AMC 360 Smoking jp360cj Jeep CJ Forum 5 03-29-2009 09:19 PM
Smoking CJ7 Subman Jeep CJ Forum 2 03-08-2009 06:42 PM
Smoking and really hot dhavard Jeep CJ Forum 15 12-11-2007 02:19 PM
Smoking. What are the possibilities? ClarkGriswold Jeep CJ Forum 13 03-24-2007 08:49 AM
Smoking 304 arkiemurph Jeep CJ Forum 14 03-09-2007 10:05 AM
