258 smoking - JeepForum.com
post #1 of 3 Old 05-22-2010, 11:12 AM Thread Starter
Surf2679
258 smoking
258 smokes when warmed up not when cold, smells like oil, does not billow, just steady flow. Valve seals or piston rings? This Jeep has done some sitting.
Surf2679 is offline
post #2 of 3 Old 05-22-2010, 01:35 PM
1986cj
Time for a compression test wet and dry. Valve seats, guides, or rings. Valve seals would let it smoke on start up and it would mostly go away after it burned off any oil that dripped down there. Mine with bad seals only smoked for a minute or two on start up.
1986cj is offline
post #3 of 3 Old 05-23-2010, 01:01 PM Thread Starter
Surf2679
I will definitely do that, but as I look more at this, the smoke really seems to be coming mostly from the exhaust manifold where it meets the pipe in the engine comparmtent. It's almost like it's overheating (I have no working temp gauge so it could be) except coolant seems to be flowing. I am going to try capping of the heater system in case there is a leak where it goes through the manifold and that's what's burning.
Surf2679 is offline
AMC 360 Smoking jp360cj Jeep CJ Forum 5 03-29-2009 09:19 PM
258 Smoking jmdkb12 Jeep CJ Forum 11 03-22-2009 12:30 PM
Smoking CJ7 Subman Jeep CJ Forum 2 03-08-2009 06:42 PM
Smoking and really hot dhavard Jeep CJ Forum 15 12-11-2007 02:19 PM
Smoking 304 arkiemurph Jeep CJ Forum 14 03-09-2007 10:05 AM
