258 running hot?? - JeepForum.com
post #1 of 6 Old 04-02-2009, 09:13 PM Thread Starter
Johnnylaw
258 running hot??
I just installed an electric water temp gauge. I didn't trust the factory gauge in the speedo. It would only go up about a third of the way and would never flucuate no matter the driving conditions. So after I installed the new gauge I noticed at idle it was running about 180*. Took it for a easy drive, with some incline for about 10 miles and it was running at 210*. How hot should it get, seems a little high to me. Thanks.
Johnnylaw is offline
post #2 of 6 Old 04-02-2009, 09:16 PM
CrazyHorse6
1979 CJ7
What thermostat does it have in it right now? 190? How does the engine run - timing good?
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #3 of 6 Old 04-02-2009, 11:03 PM Thread Starter
Johnnylaw
Not sure what therostat it has in it. It runs good, timing is set at 8* with the juicebox TFI upgrade.
post #4 of 6 Old 04-04-2009, 08:16 AM
Bubba Ray
Buy a new thermo and install or do the meat thermo in the rad neck test.
Bubba Ray is offline
post #5 of 6 Old 04-04-2009, 08:52 AM
CrazyHorse6
1979 CJ7
I picked up the radiator cap with built in thermometer from Advanced auto -works pretty well as a 2nd opinion.
post #6 of 6 Old 04-05-2009, 06:13 AM
Mike Romain
Stock you are supposed to have a 195 thermostat in it so that is as 'cold' as it should run, 180 is too low... 210 sounds just right, a 50/50 mix of coolant is good to about 265 before boiling over.
Mike
Mike Romain is offline
whats your 304 running temp? got air in my system...been running alittle hot. meatloaf Jeep CJ Forum 6 04-27-2009 04:57 PM
Trying to get her up and running again!! mudslingertj24 Jeep CJ Forum 4 07-28-2008 07:29 PM
My CJ is up and running! TiogaCJ Jeep CJ Forum 8 12-03-2006 10:04 PM
New 401 running HOT rmontgomery2006 Jeep CJ Forum 24 11-18-2006 06:32 AM
running HOT blacksambellamy Jeep CJ Forum 26 04-14-2005 08:14 AM
