Quantcast 258 Rebuild Cost? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 258 Rebuild Cost?
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 09-16-2006, 06:04 PM   #1
ClarkGriswold
258 Rebuild Cost?
Does anyone know the approximate cost of rebuilding a 258 I6? Assuming someone else does it and includes new intake / exhaust valve stem seals and new piston rings. Any suggestions on what to replace other than what I've mentioned?
ClarkGriswold is offline   Reply With Quote
Old 09-16-2006, 07:08 PM   #2
CJ51973
CJ51973's Avatar
I rebuilt mine about 5 years ago. Had the block tanked and the cylinders bored. Didin't need the head work. Master rebuild kit. Turned the crank. Had to put in a cam & new pistons. It ran about $700 with me doing the assembly.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline   Reply With Quote
Old 09-17-2006, 06:24 AM   #3
solitudetree
If you are rebuilding, you should also consider a 4.0 head swap.
http://www.geocities.com/035jeep/Moparpage1.html
Check this site out for what to do and the total cost breakdown.
http://www.monsterslayer.com/jeep/TimsEngBuild.htm
[COLOR=DarkGreen][FONT=Century Gothic]All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
[/FONT][/COLOR]
solitudetree is offline   Reply With Quote
Old 09-17-2006, 05:48 PM   #4
84 CJ7
84 CJ7's Avatar
I just completed a rebuild about 2 months ago. One of the guys at work took it out and re-assembled it. We sent it off to get everything done, they cleaned, polished, ground......... We put in top of the line parts and replaced the water pump before putting it back in. The total cost was about $1,500.00.
Mark
84 CJ7 is offline   Reply With Quote
Old 09-17-2006, 06:41 PM   #5
ClarkGriswold
Can you tell me who did the work? I assume you didn't have it done locally.
Old 09-17-2006, 08:18 PM   #6
gumby
I have a crate 258 with 17k on it you can have for $250
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline   Reply With Quote
Old 09-18-2006, 08:51 AM   #7
onesourcemike
1983 CJ7
Try ATK motors. Great crate motor for $1500.00.
onesourcemike is offline   Reply With Quote
Old 09-18-2006, 03:39 PM   #8
ClarkGriswold
Where's is it located and can you tell me more about it? Long or short block? Why are you selling? What's the 'good, bad, & ugly' on the motor?
Old 09-18-2006, 08:59 PM   #9
86cj74.2L
I paid 1500 for mine as well is was a total rebuild. New guides in head, seals etc... a replacement crank...., new cam, excellent job.
Compaired to the Crate Motor from AJ's Machine and Marine the new motor was a rolex watch and AJ's was a 3 dollar HO-Chi-Min watch from wallmart.
You're a little far away for Pete to do one for you.
86cj74.2L is offline   Reply With Quote
Old 09-19-2006, 05:47 AM   #10
moloss
I just put a Groom reman motor in my CJ....I think it was like $1400 and for another $160 I got a life time warranty.....not a bad deal in my opinion.....they are based in Nashville.
"Do your duty in all things. You cannot do more, you should never wish to do less." Robert E. Lee
moloss is offline   Reply With Quote
Old 09-20-2006, 06:33 AM   #11
ClarkGriswold
Was that just the motor or the remove/intall labor also? Nashville is only 2 to 3 hours from me and would be doable if the price is right. Do you have a web site or info on Groom?
Old 11-28-2007, 09:52 PM   #12
kconnor123
1978 CJ7
Bump.
So the consensus way back in 06 here is that your professionally rebuilt 258 (from a reputable shop) is better than these 1500 a pop crate engines you see all over. Why? They run those crate engines through the rebuild like a mill?
1978 CJ7 I6, 2.5" dik cepek spring lift, 0.5" shackle lift, Cooper Discoverer S/T 33's, 1.25" Wheel Spacers.
http://i255.photobucket.com/albums/hh157/kconnor123/CIMG1504.jpg?t=1221918667
Whats Next: Wide track swap, winch, new seats, eventually a 4.0 mpi swap from a 90's cherokee or wrangler.
kconnor123 is offline   Reply With Quote
Old 11-13-2008, 11:33 PM   #13
sparctacus
bump. I'd like to know this as well.
sparctacus is offline   Reply With Quote
Old 11-14-2008, 07:32 AM   #14
whittlecj
1980 CJ7
For a stock application, I think the the professionally rebuilt 258 is better because you get higher quality parts. I just went through a tear down of my "re-manufactured" 258 and I was disturbed by several things - timing chain was stretched too far, bearings were hardly worn but the clearances were out of spec, the oil pump was barely in spec but not close to ideal, some other little things bothered me as well. The problem here is while that reman was done several years ago, there haven't been many miles on it, most likely less than 10k. I had the engine out because one of the cheap lifters in there had failed.
There seem to be higher quality reman motors available, but they are not cheap. Jasper, Hesco, and Golen are the ones I noticed. There are many 1700$ types out there, and maybe they are okay, but I couldn't go that route again although I would of if my purpose was to get a new clean engine install and then sell the jeep soon.
If you are doing the R&R work, I'd consider talking to a few machine shops in your area to see what they have to tell you. If you are having the engine pulled, maybe consider a Jasper installer so you can take advantage of the relationship between Jasper and the shop.
YMMV- please note that I don't have any experience with the builders mentioned, I only mention them after I did some extensive research on the subject of the past few weeks. I went with option c) none of the above and am installing a 2002 TJ motor and trans along with the 2002 engine management systems. We'll see if I ever get that done.
whittlecj is offline   Reply With Quote
Old 11-14-2008, 12:46 PM   #15
stephens_cj5
1981 CJ5
I paid 800 to have the bottom end completely rebuilt with quality parts and another 400 for a Clearwater 4.0 conversion cylinderhead.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline   Reply With Quote
Glock Forum
