#1 | |
258 parts interchange
Just picked up a 258 off CL cheap. Wanted it as a spare for my 83. Engine code says it is a 73 "A" code. (standard compression). After doing a little minor research on the net, it is listed as 110 hp. I assume that that is due to the 1 barrel carb? Are all the accessories interchangeable off my current block? (Intake, exhaust manifolds, accessory brackets?) I would assume that if my current engine went down I would have to use the 73 head as a complete assembly due to valve cover design?
Thanks for any comments/advice!
#2 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I swapped a 1 BBL 78 engine into my 86 and used the 86 manifolds and valve cover because the 78's cover was cracked. I had to move the rocker bridges over for the cover swap.
I don't remember having any issues doing it.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
