258 Overheating - JeepForum.com
post #1 of 19 Old 06-04-2013, 07:17 PM Thread Starter
upcongang
258 Overheating
258 Overheating
New head gasket, new water pump, new thermostat, still have the problem.
upcongang is offline
post #2 of 19 Old 06-04-2013, 07:35 PM
pman
When are you overheating? Stoplight, highway, etc.
A couple of things to check-
- air in system?
- are you still running the thermal clutch fan (stock)? If so, this may be bad. Had the same problem on my Wagoneer at one point. Even though the fan "tested" fine, it wasn't. New fan dramatically reduced my engine temps.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3 of 19 Old 06-04-2013, 08:03 PM Thread Starter
upcongang
overheat
In less than 3 minutes it will overheat no matter what I'm doing with it. No clutch fan....New head gasket....new thermostat....and burped the system. Coolant system is under a lot of pressure.
post #4 of 19 Old 06-04-2013, 08:08 PM
pman
Have you checked the timing?
Edit: another thing to check would be incorrect backpressure. Do you have a vacuum gauge?
pman is offline
post #5 of 19 Old 06-04-2013, 08:25 PM Thread Starter
upcongang
overheating
no. Is it possible to have a cracked head and not have fluids swapping. Such as water in the oil and so on?
post #6 of 19 Old 06-04-2013, 08:28 PM Thread Starter
upcongang
Timing in on the money. 5 degrees advanced for elavation
post #7 of 19 Old 06-04-2013, 09:35 PM
dirtdudeaz
1983 CJ7
Was your motor recently rebuilt/bored or were you just doing the head gasket? Could be generating more heat if it was bored.
dirtdudeaz is online now
post #8 of 19 Old 06-04-2013, 10:21 PM
BagusJeep
1981 CJ7
Are you sure it is overheating? The gauges are unreliable and if you have the wrong sensor it can indicate overheating.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 19 Old 06-05-2013, 12:06 AM
titomars
1981 CJ7
Yes it is possible and likely a cracked head will not dump coolant into the oil.
But a cracked head will not overheat the engine in 3 minutes from cold. It will over pressure the cooling system.
my first guess is either the wrong head gasket or it is on backwards. that's about the only thing that could do it in 3 minutes. Even if the water pump was dead (no belt) it would take about 8 to 10 minutes to get to over heat from cold.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #10 of 19 Old 06-05-2013, 07:35 AM
Balvar24
1979 CJ7
It takes more than 3 minutes for me to reach operating temperature. Sounds like you've got water blocked somewhere. The head gasket thing sounds plausible.
Is the thermostat in backwards?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #11 of 19 Old 06-06-2013, 08:05 PM Thread Starter
upcongang
overheating
Well put block sealer in and let set for 24 hrs. Put new bottom hose/w spring in today.......Started it up burped the system and all was good for about 2 hrs....and then...... same old crap started heating up fast. Head gasket on right and it was overhauled before I bought the jeep about two months ago.....Any ideas where to get another head for a 79 258 AMC inline 6 in AZ:
post #12 of 19 Old 06-07-2013, 04:01 AM
Caish
1987 XJ Cherokee
I agree, I have an air lock.
Remove the temp sensor from the head and fill you'll coolant comes out or you can see it in there.
Should fix the problem....
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #13 of 19 Old 06-07-2013, 06:06 AM
keith460
Jeep. There's Only One
keith460's Avatar
That would be my guess as well.
1984 CJ-7 Renegade
keith460 is offline
post #14 of 19 Old 06-07-2013, 06:10 AM
thompsoj22
possibly "pumping" air
the fact that block sealer had an effect might indicate that the head is cracked and pumping compression into the cooling system giving you the air pocket. if you have a coolant system pressure tester put it on the radiator cold and start the motor and see if it indicates static pressure simply from starting the motor. another way would be to lower the coolant level in the top tank and run the motor til the thermostat opens and see if the temp stabilizes without overheating, it cant build system pressure without the cap. uh, dont get burned/scalded if it burps when the stat opens.
thompsoj22 is offline
post #15 of 19 Old 06-07-2013, 11:02 AM
LumpyGrits
You have a plugged radiator for sure.
You will have to have a 'rod-out' done.
If your using a fan clutch. Make sure yours is built to turn the correct rotation for your engine set up.
LG
LumpyGrits is offline
258 , overheating
