258 No compression, Valve Cover off, What's missing? - JeepForum.com
post #1 of 64 Old 09-22-2008, 01:02 PM Thread Starter
whittlecj
1980 CJ7
Check this out. Any clue why- how???? I checked this motor when I bought it and found 120# compression in this cylinder according to my notes. Since then I've had no motor issues and have not taken the v/c off. The motor runs smooth (or at least I thought so) without this cylinder.
whittlecj is offline
post #2 of 64 Old 09-22-2008, 01:16 PM
j33pman
I think I see a missing pushrod on #2 cylinder
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #3 of 64 Old 09-22-2008, 01:20 PM Thread Starter
whittlecj
1980 CJ7
Bingo - How the heck does that happen????
post #4 of 64 Old 09-22-2008, 01:33 PM
Johnyakimo1855
You better check for it in the oil pan or the lifter completely shelled
Johnyakimo1855 is offline
post #5 of 64 Old 09-22-2008, 01:37 PM
Wshift
1987 YJ Wrangler
I swear those engines eat parts, i had the same thing happen to me except i never did find the rod... the lifter was fine tho
POLYGOATS Offroad
Originally Posted by 4RunnerKid
this thread isn't a fat girl... no one here is going to give you **** for taking advantage of it
Obesity runs in her family, and it runs FAST.
Wshift is offline
post #6 of 64 Old 09-22-2008, 01:59 PM Thread Starter
whittlecj
1980 CJ7
So ---- there is a chance the lifter fell apart leaving the rod to fall down past everything into the oil pan? Idea on where to go next?
Time for a 4.0 swap or is it possible that thing thing could be fixed pretty simply (replace lifter/rod?) The other cylinders all had 120# dry & wet except #6 which had 145#.
post #7 of 64 Old 09-22-2008, 02:08 PM
Johnyakimo1855
Well I would go ahead and pull the motor and tear into it. That is my .02. You need to see where the parts are and then you need to figure out why it happened.
post #8 of 64 Old 09-22-2008, 02:09 PM
Johnyakimo1855
I personally would rebuild. Mybe put the 4.0 head on the 4.2l like the others have done.
post #9 of 64 Old 09-22-2008, 02:25 PM
CJhollic
1980 CJ7
I would pull the head before I pulled the engine. It may be as simple as the PO not putting in the push rod. You will know whn you get into it. If the lifter is there and in good shape that is probably it. You may even want to drop another push rod in before pulling the head off.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #10 of 64 Old 09-22-2008, 03:13 PM
Johnyakimo1855
CJ,
He stated earlier that the cylinder had 120 lbs of compression when he bought it. It happened after he had ran it a while.
John
post #11 of 64 Old 09-22-2008, 04:07 PM Thread Starter
whittlecj
1980 CJ7
Right - which is suprising that I missed this event. There was a period when it didn't run worth a flip and maybe it happened then when there were too many things going on to notice.
post #12 of 64 Old 09-22-2008, 05:41 PM Thread Starter
whittlecj
1980 CJ7
Alright - I believe I will yank the motor then pull the oil pan and see what is in it. Regardless, I figure I will also have to yank the head, so at that point I think pulling the motor is the smartest bet.
post #13 of 64 Old 09-22-2008, 06:19 PM
JeepHammer
Running On Empty...
1973 CJ5
No reason to tear up the engine looking for a pushrod that was probably left out when assembled.
If it made it to the oil pan (Which I doubt, since there is no direct route for it to get there) and it's way too big to cause problems with the oil pump, I'd not worry about it too much.
(a mallet on the oil pan will tell you if the push rod is there, you will hear it bounce when you strike up on the oil pan)
If I took the oil pan off, I'd have a look, but I certainly wouldn't tear down or 'Rebuild' an engine that was running 'Smooth' and has good compression.
I'd try a fresh push rod in the open hole, and see if it was going to function correctly, and if it did, I wouldn't give it a second though.
Since the distributor is in one tooth off in the direction of travel,
And there is a pushrod missing,
Those are rookie mistakes...
I could use a better (Closer/Larger) picture to look at for a lot of problems, but I'd say someone left a pushrod out when they assembled this engine, or this engine, like so many of the 258's, broke a pushrod...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #14 of 64 Old 09-22-2008, 06:22 PM
CJhollic
1980 CJ7
Originally Posted by Johnyakimo1855 View Post
CJ,
John
He probably still has 120 pounds of compression. The spring will hold the valve closed. There is no push rod to open it.
The push rod may very well have been left out as I pointed out in my last post. I would put one in before I yanked the engine.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
CJhollic is offline
post #15 of 64 Old 09-22-2008, 06:29 PM Thread Starter
whittlecj
1980 CJ7
1) This distributer is off? Timing seems fine @ 8degrees
2) If the push rod broke, would it be in the oil pan?
3) Tell me what you want a picture of and I'll get it asap.
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 07:35 PM
PCV Valve location/Valve cover replacement jobst Jeep CJ Forum 2 03-28-2010 01:53 PM
PCV valve and leaking valve cover hole crrushing Jeep CJ Forum 2 02-08-2010 05:44 AM
Compression Re-Test, bad valve, rings or both? 243 Jeep CJ Forum 0 06-19-2008 08:04 PM
Valve cover replacement (am i missing a bolt somewhere???) valkadesh Jeep CJ Forum 7 07-23-2007 01:28 PM
