258 needs new carb - JeepForum.com
post #1 of 6 Old 10-09-2009, 04:07 PM Thread Starter
1skyking
258 needs new carb
Can anyone shed some light on a new carb for my 258 I6 CJ7? Just discovered that the Carter carb needs to be replaced. I dont do much off-roading but I like the idea of more hp.
I seamless install would be preferred.
thanks in advance,
jt
1skyking is offline
post #2 of 6 Old 10-09-2009, 04:24 PM
Blthomas
Blthomas's Avatar
1979 CJ7
thanks in advance,
jt
Weber makes a good carb, 32/34 I think if you're stockish. Search around here for that and the MC2100 conversion.
I have a Motorcraft MC2100, converted to manual choke, it's butt simple to rebuild. You can do it yourself, seriously. It's way easy if you take your time.
Find one in a junkyard and go. Need an adaptor, found through several places.
A throttle linkage adjustment, or simply buy a new throttle cable (search for that part #) and it's damn near plug n play.
You can buy a "kit" from a guy on Ebay for $300ish. Comes with everything for this carb to be installed on your CJ.
I chose to get a junkyard carb, rebuild, get an adaptor, cut my own gaskets, convert to manual choke, buy the throttle cable, and love it. Does really great.
User named Coas has a cool PDF with tons of info. Several other excellant resources here.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #3 of 6 Old 10-09-2009, 06:11 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
I also put the mc2100 on a couple years ago.. bought an old one from some guy here on the forums, rebuilt it, got the adapter from summit, also converted to the manual choke.. works great.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #4 of 6 Old 10-09-2009, 07:09 PM
Olrev
1981 CJ7
I'm not sure what you mean my "seamless install"...but I've been using the MC2100 for a while and it's night and day from the BBD. I had to dig around in some junkyards to find a core, figure out which rebuild kit worked on it, match the jets to my application (which took some more digging in junkyards), fiddled with the best linkage, played with the return springs until I got 'em like I like 'em, and some other fun stuff. To me it was seamless but it took 6 months to get it perfect. It sure didn't come in a box with instructions...but I've had a ton of fun figuring it all out. You can do the kits from ebay...or a Weber...but even then, I don't know if "seamless" would define the experience. Whatever you do, jump in and learn all you can about the new carb.
81CJ7, 258, MC2100, TeamRush'd, 3"lift, 34x10.50TSL's, 3:31gears, Scrambler cab
Olrev is offline
post #5 of 6 Old 10-09-2009, 07:25 PM
CJhollic
1980 CJ7
A weber 32/36 is an excellent way to go. Order the K551 conversion kit and you can be done in an hour. It contains all the linkage and adapters. About as seamless as you can get.
I got mine from the last link. Compare pricing on all three.
Weber | Carburetors| Carbs| Online Catalog - Jeep-Toyota-Suzuki-Nissan-Mazda-BMW
CARBS UNLIMITED INC. carburetors including Weber Edlebrock Holley Quadrajet
REDLINE - Serving the U.S., Canada, Central and South America for over 30 years
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #6 of 6 Old 10-09-2009, 08:24 PM
Fjguercio
1978 CJ7
Here is a write up for you on the Weber 34 but it also can be used for knowledge on the other webers too. Also note the tricks listed to make your cj run better, TeamRush, Nutter, Grounds,
Weber 34 Tune & Jet Thread, plus jeep tricks to do
http://www.jeepforum.com/forum/f8/we...-258-a-631105/
Fjguercio is offline
Carb return line leaking.........too much pressure? And other carb questions. Blthomas Jeep CJ Forum 0 06-01-2009 09:04 PM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
Best carb for 304?! durdenclub Jeep CJ Forum 11 09-22-2004 06:41 PM
