258 intakes - JeepForum.com
post #1 of 6 Old 11-17-2005, 08:51 PM Thread Starter
petey156
258 intakes
Are all years of 258 intakes and exhaust manifolds the same? did they offer the 258 in any other vehicles?
what years are the same?
thanks u'all
Preston
I have a 77 , if it matters.
petey156 is offline
post #2 of 6 Old 11-18-2005, 04:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
From what I've seen there is one type of 1 bbl manifold and 2 types of 2 bbl manifold. One 2 bbl manifold bots to the intake for a heat riser and the other 2 bbl manifold is seperate from the exhaust and is water heated.
I think the last design is the best af as stock manifolds go.
Now there is a dizzing array of aftermarket available from 1 to 3 carbs to MPI.
John Strenk is online now
post #3 of 6 Old 11-18-2005, 09:55 AM
jadams68
jadams68's Avatar
The '85 and '86 intakes have a slightly different casting which works better with aftermarket headers. I of course used an '84 and had to grind it...DRAT!
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #4 of 6 Old 11-19-2005, 10:44 PM Thread Starter
petey156
so if i use the intake and exhaust from an 85, will it fit on my 1977 258 I6?
thanks for the HELP!
Preston
petey156 is offline
post #5 of 6 Old 11-20-2005, 09:36 PM
medunwoody
Does intake manifold for 2 barrel carb only have one retangular opening?
I've got an engine that I'm having trouble getting to run which came with a basket of mismatched parts for a carb. I can't determine what year the engine is or even if it should have a single or two barrel carb. I believe it is a 258 engine. I can't find any engine code markings that correspond to the manual I have. If the local Auto parts store only has a choice of a single barrel or a double does this mean one or the other should work? My manifold opening is about 1 1/2 by 4 inches and I assume it is a 2 barrel but ?
1985 CJ-7 with 4bt Cummins Turbo Diesel, nv4500, dana 300, 4.56 gears in stock axle housings just waiting to blow up with the extra power!
Columbia, MO
medunwoody is offline
post #6 of 6 Old 11-21-2005, 03:38 AM
John Strenk
1976 CJ5
the one barrel has one hole and the 2 barrel has two holes. Maybe someone machined out the spacer between the holes for mor flow. the two barrel has 4 bolts the 1 barrel has two bolts.
Yes either one will work, but the 2 bbl will have more options for different carburators swaps.
A question about 258 Intakes and Carb Upgrades 78CJFIVE Jeep CJ Forum 4 11-05-2009 07:39 PM
