258 injection - JeepForum.com
post #1 of 5 Old 03-27-2004, 01:00 PM Thread Starter
rblackwell
rblackwell's Avatar
258 injection
I have the option of a trade; some tires for a fuel injectyion system but I don't know if a '95 4.0 EFI will work on my carburated '86 258. First Question; Does anyone know if a '95 4.0 intake system will fit on an '86 4.2 (258) head? 2nd question; if that doesn't fit will a 4.0 head fit on a 4.2 block? Any help in this matter will be greatly appreciated!
Thanks
Reuben
'85 CJ7, 7" Lift w/37 x 13.50 Boggers, 258 6 cyl., Dana 300 TC w/twin stick shifter, spooled front & rear, D44, 5.13 gears, full cage.
New Addition: 03 Rubicon stock (For Now)
rblackwell is offline
post #2 of 5 Old 03-27-2004, 01:27 PM
wm69
a 4.0 head will not only fit on a 4.2, it will give you a sig. increase in HP. Here's a link for the head swap and I'd definately swap tires for FI. Just make sure the guy has the complete FI system. There will be a wiring harness and I think you have to run a high pressure fuel pump for the FI system. Anyhow, here's a link for the head.....
http://www.monsterslayer.com/jeep/40Head/40Head.htm
wm69 is offline
post #3 of 5 Old 03-27-2004, 02:02 PM Thread Starter
rblackwell
rblackwell's Avatar
Thanks for the info, I will make sure I get everything I need!
post #4 of 5 Old 03-28-2004, 02:08 PM
hoodedrat
they fit with modification
you have to do some work to the head to make it fit or there are companies that make conversion heads.
you mite consider swaping in your 258 crank and rods in to a used 4.0 it will give you a lot more displacement just make sure you use a 92 or newer they had the high output heads it is pretty streight foward do a search on stroking the 4.0 and you will find all you need.
RED 5 STANDING BY
Red 76 cj5 258 soon to be 360 t150 4 inch pro comp shackle reverse k&n 2 bbl upgrade 2 1/4 exhaust glasspack
hoodedrat is offline
post #5 of 5 Old 03-28-2004, 05:09 PM Thread Starter
rblackwell
rblackwell's Avatar
Thanks for the info I've been doing a lot of research and there is only minor alterations to make to a 4.0 head in order to put it on a 258. The alternative route (probably the cheapest) is to do exactly what you said get a used 4.0 and stroke it out. The problem is I just spent $800 to get my 258 rebuilt!
Thanks again
Reuben
Fuel Injection 304 Exposed Jeep CJ Forum 5 11-20-2008 06:40 PM
Ari injection pump for OBA??? sanmiam Jeep CJ Forum 4 03-16-2008 10:16 PM
258 MPI Injection okjeep98 Jeep CJ Forum 8 12-09-2005 02:13 PM
Injection Tbi alldun5 Jeep CJ Forum 3 03-12-2004 09:14 AM
CJ-5 Injection spit15 Jeep CJ Forum 1 01-28-2002 07:44 PM
