258 Holley Carb, Choke Stuck Closed - JeepForum.com
post #1 of 6 Old 10-17-2009, 05:57 PM Thread Starter
SEALLogan
Hi,
I searched around, but could not find anything similar to my problem.
It is about 35 degree's here now, so it isn't fridgid, but it is cool. This is my first time running the jeep since it has gotten cold. We just got it this summer, and it has run pretty good during the warm months.
I went to start the jeep today, and it idled very high and had a lot of white smoke. I let it warm up for a good bit, and then went to drive it around to the garage to work on it. When I pushed on the gas to get going, the engine speed did not increase at all. I held the gas just above idle for about 10 seconds before the engine speed started to pick up at all. I let off the gas and the engine started running at a normal idle speed, but very rough.
Then the engine died. I went to restart it, and it wouldn't start. So I turned the key again, and the starter wouldn't even turn the motor. I waited 10 minutes, and the starter would turn the engine, but it wouldn't start.
I pulled the air cleaner off of the Holley carb with electric choke. I noticed the choke was all the way closed. I went to open it manually, and it wouldn't even move. I thought it was froze shut, so I put a little heat to it. That didn't free it. I hit it hard with the back of a screw driver, and it popped lose. Then it moved freely.
I tried to crank the engine again, but it wouldn't start. Went to crank again, and the starter, once again, wouldn't turn the motor. Checked the choke, stuck closed again.
I'm not sure where to start. Sorry the post is so long, just trying to include the details,
Thanks!
SEALLogan is offline
post #2 of 6 Old 10-17-2009, 06:18 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Look for something binding. Mark a reference mark on the choke housing and the carb, remove the electric assembly and look for anything not right. Something in the linkages sounds to be binding.
Rick
Cutlass327 is offline
post #3 of 6 Old 10-17-2009, 06:25 PM Thread Starter
SEALLogan
I actually have been messing with it, and the linkage is free. The plate itself is jamming. It seems that the choke is closing too far, and binding shut.
I think I have two issues. I just tried to start the jeep again, and you can hear the starter solenoid click, but the starter doesn't turn. The battery is good, I already tested it.
post #4 of 6 Old 10-17-2009, 06:32 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Sounds like a new starter or remote solenoid, whichever yours has. Isn't there a set screw to adjust how much the choke closes? You usually want an opening the size of a pencil's diameter...
Rick
post #5 of 6 Old 10-18-2009, 07:03 AM Thread Starter
SEALLogan
I'll have to do some more digging around. I haven't seen a screw to adjust that yet...but it would make sense. That may explain why it has always started hard.
Is this what happens when a starter dies? I thought it would die a slow death, not just stop working....but I have never had a starter die before.
post #6 of 6 Old 10-18-2009, 08:01 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Ok, reread the post. Solenoid clicks but starter doesn't move - either a dead spot in the starter, bad contacts internal of the solenoid, or bad starter ground. These are the most common causes of solenoid click/no movement.
Rick
304 + Holley 470 CFM TA, electric choke - Cold starts suck PhatBasturd Jeep CJ Forum 36 05-29-2010 02:21 PM
Holley carb Q BaliJeeper Jeep CJ Forum 5 04-14-2009 12:11 PM
Holley 600 1850-3 Choke Question Pugnacious Jeep CJ Forum 3 10-12-2008 10:42 AM
Where can I buy a temperature-controlled choke for my Holley carb? part.changer Jeep CJ Forum 2 08-07-2008 01:09 PM
holley manual choke atomicflatulenc Jeep CJ Forum 4 03-08-2008 07:20 AM
