258 HEI conversion HELP PLZ!! - JeepForum.com
post #1 of 2 Old 09-29-2002, 07:52 AM Thread Starter
BADEAGLE
Question 258 HEI conversion HELP PLZ!!
Hello all Hope someone here can help me. I am in the process of changing my stock distributor on my 86 258 inline six to a GM HEI. I am changing because my spark control box has crapped out and not worth the money it takes to get a new one. I purchased a complete GM six cylider distributor that is all ready to go. My problem is with the distributor gear?? I removed the gear that was on the GM HEI, THen I removed the gear from my stock distributor out of jeep. I had a friend who has a machince shop machine the gears to match in heigth. It came out perfect looks like it was made that way. Now when i put it on hte GM HEI shaft and drive the pin back in there is play in the gear. I miched the shaft of old distrubutor and HEI and found about .20 differnce in shaft size. I was wondering if anyone else had done this and will it be all right or not??? I am afraid it will wear funny causing problem to gear or worse yet the cam drive. I have had no luck around our town finding and Amc v8 gear. I did find one on www.4wd.com part #3208615 if i buy this gear will it fit the shaft better?? thanks in advance for any info or advice!!!!!
BADEAGLE is offline
post #2 of 2 Old 09-29-2002, 09:20 AM
CSP
The AMC V8 gear fits the HEI perfectly. With play you'll damage the cam drive, the distributor drive, and your timing will jump all over the place.
CSP is offline
SR4 to T5 conversion ghawki Jeep CJ Forum 15 03-01-2010 07:13 AM
AX 15 conversion ego99 Jeep CJ Forum 10 12-26-2007 02:27 PM
258 to 360 conversion jeepin'fool Jeep CJ Forum 8 01-05-2006 07:58 AM
SOA Conversion nsamaster0414 Jeep CJ Forum 1 12-29-2004 06:15 PM
4X2 Conversion mrkelly Jeep CJ Forum 5 11-22-2003 10:38 PM
