258 Heater hose routing - JeepForum.com
post #1 of 9 Old 01-02-2014, 08:43 AM Thread Starter
dmoore_64
1974 CJ5
Hey guys!
I have an 82 258 engine in my 74 cj5, and I am not sure of the heater hose routing. It has the coolant passage through the intake manifold. The way that I have it ran is, heater hose from small port on water outlet to front port on intake, from rear port on intake to port on heater core, from other port on heater core to small port on water pump.
My problem is that it never seems to get above the lower mark on the temp gauge and my heater only blows out warm air, never hot air.
dmoore_64 is offline
post #2 of 9 Old 01-02-2014, 09:32 AM
CSP
Your hose routing is correct. Is the coolant itself getting hot? If so, I would suspect blockage in the heater core possibly.
CSP is offline
post #3 of 9 Old 01-02-2014, 09:56 AM Thread Starter
dmoore_64
1974 CJ5
Hoses seem to be getting hot, and heater core was replaced about a year and a half ago, when I rebuilt Jeep.
post #4 of 9 Old 01-02-2014, 11:41 AM
CSP
Perhaps there's an air bubble in the loop preventing coolant from circulating in the core.
CSP is offline
post #5 of 9 Old 01-02-2014, 01:14 PM
EgulAye
1980 CJ5
The top of the heater core should be the inlet from your intake manifold. The bottom is the outlet to the water pump. I just switched mine yesterday to match the TSM and it's made a difference. (mine is a '78 232 in an '80 CJ5, but I suspect the setup is/should be the same)
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #6 of 9 Old 01-02-2014, 01:22 PM
gosupes
Originally Posted by dmoore_64 View Post
Hey guys!
What temp is your t-stat?
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #7 of 9 Old 01-02-2014, 01:38 PM Thread Starter
dmoore_64
1974 CJ5
It is a 195 deg t-stat. Could be a bubble but I don't think so, I have had it running with cap off many times.
post #8 of 9 Old 01-02-2014, 04:27 PM
CSP
Taking the cap off won't eliminate a bubble in a spot that's higher than the cap or even one that's lower than the cap but has coolant between the bubble and radiator.
CSP is offline
post #9 of 9 Old 01-03-2014, 01:44 AM
turkish6
1982 CJ8
What would be the proper way to remove a bubble?
turkish6 is offline
