258 and headers - JeepForum.com
post #1 of 9 Old 10-02-2002, 11:25 AM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
258 and headers
I am considering doing this. I need a new exhaust system anyway. Headman makes 6 into 1, and a 6 into 2. Which would be better performing. I don't plan on putting dual exhaust on. I am also considering a weber 2 barrel swap also. The main reson for this header swap is to remove all my smog junk because it is no complete anyway. We son't have emissions control here in Iowa so that is not a concern.
BART CJ5 is offline
post #2 of 9 Old 10-02-2002, 09:02 PM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
I did a search on this topic before posting and nuttin. Nadda, single thing. Anyone ever put a header on their inline 6? 232, or 258, 4.0?
BART CJ5 is offline
post #3 of 9 Old 10-03-2002, 05:34 PM
SevenBars
Go to site for Clifford Research. They can make your 258 run like a V-8!
SevenBars is offline
post #4 of 9 Old 10-03-2002, 08:08 PM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
BART CJ5 is offline
post #5 of 9 Old 10-04-2002, 06:45 AM
SevenBars
Yes I stand corrected, but it does say Clifford Research on the intake manifold. It might be and older one.
post #6 of 9 Old 10-04-2002, 09:02 AM
LS1CJ5
1979 CJ5
I've heard the 6 to 2 and it does sound Real Good. If you don't mind extra expense of the pipes I'd go with it.
Larry M
1979 CJ5 LS1, NV4500
LS1CJ5 is offline
post #7 of 9 Old 10-04-2002, 02:17 PM
CJay7
I have the Hedman 6 to 1 headers and they worked perfect. Felt a decent gain from them and saved money by only having to replace one side of exhaust instead of two. After considering it for a little while I really didn't see the need for 3 exhaust ports to have their own header, the stock heads don't flow that much.
Good luck.
'85 CJ-7 - 258 bored .030 w/ mid level cam, 4.0 head, Clifford intake and header, Weber 38, TFI w/ MSD 6, Black Diamond 3" lift, Daystar 1/2" lift shackles, 33x12.5 Goodyear Duratracs with stock 3.31 gears.
CJay7 is offline
post #8 of 9 Old 10-05-2002, 09:47 AM
crossbreed-cj/yj
Id say 6 to 2 headers
i have that setup on my wrangler plus a 2 1/2" double exh, system(build it myself) and flowmaster mufflers and the sound is grrrrreat!!! not so noisy in idle and when i floor it, it screams!!
and it relly woke up the engine
JEEP-everything else is just a car!
crossbreed-cj/yj is offline
post #9 of 9 Old 10-10-2002, 08:10 PM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
I'm goin 6 to 1 Hedman. Clifford Performance calims best performance with this. The other mod I must make is the Weber 2 barrel kit. My Carter 1 barrel is shot.
Who has the BEST prices? 4WD Hardware has the stuff, but it's a little pricey. I found the carb kit for $320 through www.windrockoffroad.com Thanks for all the feed back folks.
BART CJ5 is offline
What do these headers tell you? 84MSRB Jeep CJ Forum 4 05-22-2009 02:35 PM
headers, yay or nay? BlueFalcon Jeep CJ Forum 13 06-14-2007 07:58 PM
Headers for what? StewartCJ7 Jeep CJ Forum 2 06-12-2007 06:33 AM
304 Headers maxx9647 Jeep CJ Forum 1 05-24-2007 10:08 PM
304 Headers maxx9647 Jeep CJ Forum 2 05-24-2007 03:05 PM
