258 fuel economy - JeepForum.com
post #1 of 16 Old 07-10-2004, 03:54 PM Thread Starter
eprobe
1981 CJ5
258 fuel economy
I'm interested in what kind of fuel economy people out there are getting w/ their 232/258s. I get about 15 mpg w/ a 1bbl Carter on a 232 w/ 3.31 gears and 31.5" tires. Does anybody's Jeep do better and what did you have to do to achieve that? I'm particularly interested in people who may have swapped heads w/ a 4.0 or added EFI or TFI or an HEI.
Thanks,
Eric
eprobe is offline
post #2 of 16 Old 07-10-2004, 07:06 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
I get 14.5 mpg with 33" tires and a Weber 38. Not sure about my gears.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #3 of 16 Old 07-10-2004, 08:13 PM
djfuzzy
I figure I get about 17mpg - but....all of my guages are out of whack except for my odometer so I don't really know.
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #4 of 16 Old 07-11-2004, 11:10 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
With the MPI kit, 31" 5-speed, and 3.31, I get over 20 mpg, close to 25 at times, on the highway, if you can beleive that. That's really the only time I calculate it.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #5 of 16 Old 07-11-2004, 11:48 AM
gosupes
Between 15 and 18 depending on type of driving with 4.10 gears, 31" tires and 5 speed trans.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #6 of 16 Old 07-11-2004, 12:34 PM
80cj
80cj's Avatar
1980 CJ5
Mine is a 80 CJ-5 with 4.10 gears 31 inch tires and a T-176. I haven't corrected the speedo since installing the 4.10s. Mileage is lousy ...probably about 12-13 mpg. I used to get between 15 and 17 with the old 3.54 gears.
80cj is offline
post #7 of 16 Old 07-11-2004, 01:10 PM
SamFromCO
SamFromCO's Avatar
'86 CJ7, 258 w/Mopar MPI kit, 5 speed transmission, 35" tires, 4.56 gears=20 mpg highway (I seldom drive it around town so I don't know about that)
'86 CJ7, 258 w/Mopar MPI, 4.56 gears, rear Detroit/front Truetrac, full cage, OBA, 8274, 4" lift via Alcans/Rancho, 35's on beadlocks, other stuff. Built for rocks, mud is a four letter word.
SamFromCO is offline
post #8 of 16 Old 07-11-2004, 01:55 PM
jeepsarecool
1982 CJ7
20 mpg???? Are you suuuure about that?
Check out my
post #9 of 16 Old 07-11-2004, 04:47 PM
OL YELLAH
OL YELLAH's Avatar
14-15 mpg with the engine mods listed below, 3-speed, and 3.73 gears. That's pretty much all highway driving.
1979 Jeep CJ-5; 1972 258 (Pacesetter Header, Weber Carb, Wrangler Aluminum Intake, 2.5" Exhaust Straight Through w/ Thrush Mufflers); 2.5" BDS Lift; 1" Daystar Body Lift, Herculiner; RJS Belts; 33" Interco Trxus M/T Tires; Xtreme Alloy Wheels; 2.5" Perfomance Wheel Spacers; TFI Upgrade.
OL YELLAH is offline
post #10 of 16 Old 07-11-2004, 06:40 PM
SamFromCO
SamFromCO's Avatar
Yep, I've checked it several times. And, if you found that hard to believe you'll probably have a harder time with this, that's over the mountains. About the only time that I ever really check mileage is on my trips from Denver to Moab and back. I believe that my odometer is pretty close and have checked it several times with my GPS. Also I roughly know the distance between gas stops. 19-20 mpg! The only catch is that I have to run premium unleaded to keep the motor from pinging.
post #11 of 16 Old 07-11-2004, 10:28 PM
Aphelion79
Aphelion79's Avatar
Any idea what rear axle you have?
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
post #12 of 16 Old 07-12-2004, 11:16 AM
jeepsarecool
1982 CJ7
Yeah, I have the AMC 20 rear.
Check out my
post #13 of 16 Old 07-12-2004, 06:19 PM
Aphelion79
Aphelion79's Avatar
To find your gear ratios (if stock and no one has done any upgrades etc) look at the rear of your 20
Rear View
Driver's Side (|)---=(+)=---(|) Passenger's Side
The right most = sign is the edge of the pumpkin that has either one letter or two letters sticking out of it. This is right where the axle tub fits into the differential. The letter(s) represent the current gearing from the factory.
Code:
'81 and earlier CJs
Narrow Track AMC 20
Code  Gear Ratio  Diff Type
AA  2.73  Open
DD  2.73  Trac-Lok
BB  3.31  Open
CC  3.31  Trac-Lok
A  3.54  Open
N  3.54  Trac-Lok
GG  3.73  Open
Q  3.73  Trac-Lok
L  4.10  Open
M  4.10  Trac-Lok
'82 up CJs
Wide Track AMC 20
D  2.73  Open
DD  2.73  Trac-Lok
B  3.31  Open
BB  3.31  Trac-Lok
A  3.54  Open
AA  3.54  Trac-Lok
H  3.73  Open
HH  3.73  Trac-Lok
C  4.10  Open
CC  4.10  Trac-Lok
Mine had a single "A" sticking out (not stamped INTO the metal) showing 3.54 gearing with Open differentials (no limited slip).
1982 CJ7
post #14 of 16 Old 07-13-2004, 11:18 AM
jeepsarecool
1982 CJ7
'82 up CJs
Wide Track AMC 20
D 2.73 Open
DD 2.73 Trac-Lok
B 3.31 Open
BB 3.31 Trac-Lok
A 3.54 Open
AA 3.54 Trac-Lok
H 3.73 Open
HH 3.73 Trac-Lok
C 4.10 Open
CC 4.10 Trac-Lok
Hey, thanks for the info. I went out and checked, and if it is stock (and I'm fairly sure it is), I have the 3.31 open gears. Is that a good gear ratio? It seems to work ok with my T5 and 33" tires.
Check out my
post #15 of 16 Old 07-13-2004, 11:22 AM
Aphelion79
Aphelion79's Avatar
Well concidering its a final drive ratio it all kinda depends on what else you have... tranny, transfer case ratios .... tire size, and what you plan on doing with it... For me... I could stick with my Dana 300 and reduce it to 4:1 low and still have my high range that will work with my 4 spd on the highway... I'm not entirely too sure how well that would work... but with my 4 banger i shouldnt be able to beef out that much stress anyway lol...
1982 CJ7
Iron Duke Fuel Economy cracked91 Jeep CJ Forum 10 05-28-2009 12:33 AM
CJ-2 and CJ-3 fuel economy papogi Jeep CJ Forum 5 07-16-2008 11:26 PM
fuel economy sailkid Jeep CJ Forum 4 05-17-2006 09:45 PM
Fuel Economy nsamaster0414 Jeep CJ Forum 9 07-05-2005 09:56 PM
4.0 head, fuel economy eprobe Jeep CJ Forum 2 08-10-2004 05:52 PM
