258 EFI upgrade & YJ spring upgrade - JeepForum.com
post #1 of 3 Old 04-07-2005, 08:03 PM Thread Starter
jeepin'bo
guys, I am buying a 4.0 head, EFI, and wiring ($450!) to put on my 258 I am rebuilding. I want to make sure that I get everything, I have searched the forum and have a short list:
Valve head
EFI system
Exhaust manifold
wiring harness
valve cover
Anything else to pick up?
Also picking up a set of YJ spring holders to do the YJ spring conversion ( I will buy the 2.5" lift YJ spring set). Is there any other parts for this I need?
jeepin'bo is offline
post #2 of 3 Old 04-08-2005, 12:24 AM
jeepskate
I'd suggest that you google the head swap as well as check out the 4.0 swap forum at http://www.cjoffroad.com
For the spring swap, the rears are a direct fit. Up front you just need conversion shackles (Rubicon Express or Ebay) and u-bolt plates.
jeepskate is offline
post #3 of 3 Old 04-08-2005, 07:02 AM
jadams68
jadams68's Avatar
What year is your 258 block? If it's not a 1980 or a 1986 up, you'll need to get the block tapped and threaded for 1/2" headbolts or you'll need spacers for your 7/16" stock bolts. You can get new 1/2" headbolts at www.headbolts.com
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
Best upgrade ever! RipLip Jeep CJ Forum 11 07-13-2009 10:31 AM
CJ7 T18 Upgrade mattcj7258 Jeep CJ Forum 18 12-23-2008 07:45 AM
Upgrade 360 Whistler Jeep CJ Forum 3 10-10-2008 01:08 PM
Any of you in CA done the MPI upgrade? Jeep Daddy Jeep CJ Forum 9 12-26-2005 06:59 PM
HEI Upgrade weprint Jeep CJ Forum 2 12-06-2005 04:23 PM
