258 dipstick - JeepForum.com
post #1 of 7 Old 10-02-2013, 06:14 PM Thread Starter
apmccullen94
258 dipstick
Ok I've asked this before and haven't really got an answer. I got a 78 CJ-5 with a 258 V6. Oil leaks from around the dipstick. Not the tube, the actual stick. Looking at other's pictures, y'all have a gasket on there. I'm missing that. Is there anywhere I can order it? Or any other type of seal I can use? (ex. rubber o-ring or such) Thanks.
apmccullen94 is offline
post #2 of 7 Old 10-02-2013, 06:54 PM
LumpyGrits
Install, the CORRECT, PCV valve.
After that---I will ask how many miles on your engine and the last time you did a compression test??
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 7 Old 10-02-2013, 08:29 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
The potential problem is that combustion pressure from the exploding fuel/air mixture is making its way past the piston rings and into the crankcase. From there it could potentiall push oil out of the dipstick hole. An engine that has a cylinder or more with lower compression than the others could be a sign of bad rings, causing the aforementioned problem. The correct PCV (positive crankcase ventilation) will allow crankcase pressure/gas to vent to the intake manifold but ultimately that's not a cure for bad rings. So even if you have the correct dipstick and it fits correctly in the tube, it could still get pushed out or be prone to leaking if the rings are bad.
To answer your actual question, I don't know if my 258 dipstick has a gasket or not I never really paid attention.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #4 of 7 Old 10-02-2013, 08:54 PM
LumpyGrits
No real gasket as it's a friction fit deal at the top of the d'stick.
LG
post #5 of 7 Old 10-02-2013, 08:57 PM
supersport126
supersport126 is offline
post #6 of 7 Old 10-02-2013, 08:59 PM
LumpyGrits
Not a "V-6".
LG
post #7 of 7 Old 10-03-2013, 09:36 PM Thread Starter
apmccullen94
Fresh rebuild and brand new PCV valve and lines. And its an Straight 6, the best motor i've ever owned.
258 , dipstick , oil leak
