258 best way to turn motor over w/jumper cables - JeepForum.com
post #1 of 18 Old 10-06-2010, 09:33 AM Thread Starter
Tigerpaw
1983 CJ8
I've got a 258 sitting in the frame without the wiring harness or transmission motor turns easly at the front with a wench but when I jump the starter with cables I dont seem to get enough juice, it doesn't kick in and spin or turn motor over. Starter spins out of the jeep. Am I missing something?
Tigerpaw is offline
post #2 of 18 Old 10-06-2010, 10:30 AM
JunkJeep228
1994 XJ Cherokee
Jumper cables of any length take a ton of power from the battery, either use 2 batteries or put a charger with a start feature on, or shorten up the cables alot. If you're trying to jump it out of another running vehicle i doubt it'll have enough juice.
"Wheel it, Break it, Build it better." Words to live by.
JunkJeep228 is offline
post #3 of 18 Old 10-06-2010, 10:33 AM
JunkJeep228
1994 XJ Cherokee
Or are you saying that the gear on the starter doesn't engage the flywheel? In that case,you may have to remove the starter and check to make sure the gear assembly on the starter moves in and out freely.
post #4 of 18 Old 10-06-2010, 10:49 AM Thread Starter
Tigerpaw
1983 CJ8
When I pull the starter out and jump the starter it it throws the gear in and out, I've got lots of fire going to it mounted but it doesn't engagfe I'm carrying starter to O'Rilley to check it out, will a 304 starter work in a 258?
Tigerpaw is offline
post #5 of 18 Old 10-06-2010, 11:00 AM
JunkJeep228
1994 XJ Cherokee
I'm not sure, If you have one try it out. I'd check an auto electric shop. They're more likely to know what the problem is, and If its something small like dirt or something they'll usualy just charge 20 bucks or so to clean it out. Most chain auto parts just replace them with a mexican made chincy rebuild.
post #6 of 18 Old 10-06-2010, 01:26 PM
LSUtiger
1980 CJ5
I think all the amc used the same starter. I'm not positive for the 258 but all the v8s use the same one. I have a '72 304, '78 401 and a '86 360 and they are all the same. When I looked them up at autozones website I think the 258 was the same #.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #7 of 18 Old 08-08-2013, 03:20 PM
pfd1
I know this is an old post, but I'm having the same problem..'81 Scrambler with the 258. trying to turn the engine over just to get oil up in it. Used battery charger on "start" & the starter motor just buzzes. Engaged it manually & still nothing. The starter is new & I sanded down all conections & contact points for good ground. The engine turns freely by hand but cant seem to get the starter to turn the engine over. ???
pfd1 is offline
post #8 of 18 Old 08-08-2013, 05:31 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Are you just using a batter charger ? No battery?that won't have enough power.
John Strenk is offline
post #9 of 18 Old 08-08-2013, 08:41 PM
LumpyGrits
You need a couple hundred AMPS for start up.
Your battery charger ain't going to do it. UNLESS it has a 'start circuit' in it.
Also, cheap Wal-Mart small gauge jumper cables won't help because of the built in resentence.
Try a fully charged battery.
LG
LumpyGrits is offline
post #10 of 18 Old 08-09-2013, 07:29 AM
pfd1
Thanks for the advice everyone. When I get back home this weekend, I give it a shot with a battery..
pfd1 is offline
post #11 of 18 Old 08-09-2013, 08:12 AM
jeepwhore
LG
The cheapo cables are certainly less desirable, but I've managed to make them some what reliable.
Tigerpaw, if you are using cheap cables pull the plastic sleeves off the handles and look at the crimps. Every pair of cheap cables I have seen usually had very little wire in the crimp and also had part of the rubber outer sheathing crimped as well. Anytime I run across someone using cheap cables I'll open the crimps back up, strip more of the conductor and re-crimp it properly. It makes a huge difference and in my case stopped my cables from smoking when trying to jump my Jeep.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #12 of 18 Old 08-09-2013, 08:22 AM
CSP
It's not a good idea to turn the engine over to get oil going. Pull the distributor and engage the oil pump using any kind of tool you have that will fit in the slot and a drill at the other end.
CSP is offline
post #13 of 18 Old 08-09-2013, 06:15 PM
VooDoo2
1978 CJ7
You need a good strong battery to engage the starter solinoid. at 12.5v my car wont start. at 12.7 it does. If you have a dropped cell you wont get anywhere and batteries sitting around die faster than those that get used all the time.
VooDoo2 is offline
post #14 of 18 Old 08-09-2013, 06:38 PM
LumpyGrits
Is the battery ground attached to the starter?
Have some battery cables made from 4/0 arc-welding wire.
Almost zilch in lost amperage.
LG
post #15 of 18 Old 08-10-2013, 09:02 PM
VooDoo2
1978 CJ7
LG
No issues at all with a new battery but if I let it drain a bit i get the same issue. Grounds are new
VooDoo2 is offline
Jumper cables are smokin' Yellow79CJ5 Jeep CJ Forum 12 04-14-2010 04:43 AM
fuel guage jumper petey156 Jeep CJ Forum 1 04-27-2009 03:21 AM
Right Turn & Motor Sputters RARECJ8 Jeep CJ Forum 5 05-27-2008 03:14 PM
To see if a motor will turn over JeepRocks86 Jeep CJ Forum 22 01-30-2007 08:25 AM
HELP! Starter motor will not turn my 258 engine! Jeep256 Jeep CJ Forum 22 07-17-2004 11:33 PM
