258 to 304 swap - JeepForum.com
post #1 of 3 Old 06-18-2003, 09:56 PM Thread Starter
wiggs
258 to 304 swap
i had a question about mounting the transmission to a 304. Since it was on a 258 ive heard that the block of a inline six is longer than the 304. I was told that i would have to bring the transmission forward so it will fit onto the engine. Not sure just checkin with everybody that has done the swap
wiggs is offline
post #2 of 3 Old 06-19-2003, 07:42 AM
fuzz401
1978 CJ7
were you skid plate bolts on should be a line of holes in the frame move to what ones you need i did a 79 cj 5 and had no problem years ago
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 06-19-2003, 08:38 AM
CSP
That is false info. The transmission should stay in the same place and the motor mounts will bolt right up to the frame when the V8 is dropped in. Yes the I6 block is slightly longer, but there is just more room in front of the fan on a V8. The extra holes in the skidplates are there for the different transmissions that were available in any given year CJ. A V8 CJ with a T150 transmission has the tranny/tcase in the exact same spot as a I6 CJ with a T150.
CSP is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
yj tub swap on cj TravellinMan_15 Jeep CJ Forum 1 03-29-2009 04:14 PM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
